Passat ABS sensor
volrem
Re: Passat ABS sensor
Post by volrem » Thu Aug 11, 2016 5:42 am
Take a loot at Steve's case study for hints about measuring MRE speed sensors.
https://www.picoauto.com/library/case-s ... -low-speed
Dcunning35
Post by Dcunning35 » Sat Aug 13, 2016 7:14 am
Hi Viktor I had the same issue with a Delphi sensor on a golf last week stick with the oem part pal .
Danny
Post by victor2k » Sat Aug 20, 2016 4:34 am
The issue was solved using a oem sensor.
Thank you
Post by STC » Sat Aug 20, 2016 10:40 pm
victor2k wrote:Hello,
Thank you
OEM has become a term used very loosely lately. I blame the internet and the marketeers.
Did it come from the dealer or elsewhere ?
Post by victor2k » Mon Aug 22, 2016 8:21 am
OE does not mean original equipment?
I used the same sensor code ,made by ATE .This sensor was buyed from a multibrand shop,not from VW dealer.
At first sensor was a mistake in database,the Delphi sensor wasn't compatible with car and the multibrand shop changed the sensor .
I wonder what signal processor use the ABS unit if the state-of-art from Pico (using native 12 bit resolution) show his limits in this case...
Post by STC » Mon Aug 22, 2016 11:13 pm
And OEM = Original Equipment Manufactured ???
You and I know that Viktor but I do believe some motor factors are applying a different translation to that.
Post by victor2k » Sat May 26, 2018 7:13 am
Please remove this message.
Please delete
Post by victor2k » Sat May 26, 2018 7:16 am
Here is a captured signal from a good sensor
https://mega.nz/#!xVhzWRpZ!VmfP6NlB55j0 ... h-yOnpKDYU
and here is a captured signal from a Delphi sensor
https://mega.nz/#!lEBUDDgL!_2RNyclVvyXL ... FFupInXlQw
:shock:
