Ducati Multistrada 1000DS
dominic
Post by dominic »
HI again.
Looks like I was wrong on my diagnosis as per discussion here: http://www.picoauto.com/support/topic9272.html
I would really appreciate some assistance & guidance if its Ok to ask here?
I'll give you what I know and perhaps some light can be shed on things...
1. Bike comes in with error light on, battery over volatage ( 5.1 )
2. as in image uploaded, voltage spikes apparent and I thought regulator issue
3. replaced regulator & spikes rectified however error light still on.
4. today I noticed the volatge on the dash does NOT reflect actual battery voltage. Actual battery >14VDC dash displayed volatge max 12VDC
5. dash displayed battery voltage on this bike is via CAN line
6. ecu & dash grounds OK < .5 ohm
7. ecu to dash CAN line connections/wiring under .5 ohms.
As I am very new to scope use, CAN samples not yet taken however I have hooked up to known 2 CAN wires and data was not clear.
Should I check what is on the CAN line and watch the CAN signal as I disconnect sensors etc or some other approach.
Also does anyone know if Ducati (2005 model) use CAN high/low?
I have the genuine manual however it is not overly informative in relation to CAN type etc.
Thanks in advance.
Alan
Re: Ducati Multistrada 1100S
Post by Alan »
Is there any chance you can upload the .psdata file as well as the screen grab. If you are still connected can you use a 20ms/div timebase rather than 5ms/div as this will ensure you have at least one complete engine cycle (everything happens at least once on the engine). I assume the trace is of battery voltage and current ?
One other thing when you say "Actual battery >14VDC dash displayed volatge max 12VDC" is this a voltmeter display on the dash. If so perhaps its a software thing with the bike? Does the dash normally ever display over 12V (a normal bike with the engine running will always have >12V but perhaps the bike display shows voltages below 12V to show there is a problem but above 12V it just shows 12V to signify there is enough voltage?
Thx
Alan
dominic
Post by dominic »
HI Alan, thanks for the speedy reply.
I am at home now but can get more data tomorrow.
I will upload or PM what little .psdata I have, hopefully it will help.
It was batt voltage & current yes.
Actual battery voltage when tested at battery is over 14VDC. Yes, dash has displayed voltage and is inaccurate, and from manual is acquired via CAN. I do think from memory the dash will display correct voltage however I will test another very similar bike tomorrow ( dash cannot be swapped as coded to bike! NOT that I want to parts swap at all )
new regulator - same error.psdata
(64.45 KiB) Downloaded 726 times
dominic
Post by dominic »
Alan, your suggestion of software issue is where I am at with it. The software is in the dash I would expect. If no software in dash then just the dash. I am just wanting to be able to diagnose and not guess.
I tested all dash loom wiring voltages and interestingly, left hand switch block function related voltages(that is - high beam, indicator, horn & hazard switches) were all in the 12vdc or lower region. All other 12v wiring was as expected, actual battery voltage or very close.
Just trying to give you everything I know...
speak soon
Dom
It is one thing testing resistance & another load testing !
The grounds you checked check again with the bike running with the scope as a DMM. (black to ground (Batt -)red to ground being tested))
Does the dash receive the voltage from the ECU for the engine via CAN ?
Grab a CAN capture anyway & post it on here lets have a looksy :)
Just so you know i am not a bike guru but a few of us may be able to help with testing methods & possible results/captures.
antthecat
Post by antthecat »
Just a punt on this, is the battery good?
Alan
Post by Alan »
Yes, the battery is a suspect (as mentioned in other thread) unless already checked / swapped. Part of the job of a battery is to act as a capacitor smoothing out spikes / noise on the 12V lines.
If you are re-capturing the waveform please make sure the memory (no of samples) is turned up a bit. Its 1000 samples in your waveform. Try 100,000 or so to make sure you are sampling fast enough to capture any spikes.
dominic
Post by dominic »
Robski wrote:Dom
Robski, thanks very much re load testing grounds. yes totaly agree & thanks for showing me how to do this with the scope. tested OK
Yes, batt voltage is CAN line. I found today using texa through diag port battery voltage stays at 11VDC BUT when I switch the bike off the min/max shows as you'd expect circa 11.5/14.9VDC - so I took the CAN snapshot
Not concerned who is bike guru or not you guys are a great help and methodology is going to be very similar I would expect.
dominic
Post by dominic »
anthecat & alan, thanks for the other ideas.
I did take a sample with another battery however similar results & same error.
Thanks for advis eon sample rates. (Taking notes & samples for my library)
dominic
Post by dominic »
Here is the CAN snapshot, I will add a couple please advise which is best capture settings
