Maths is cool
- Pico Staff Member
Re: Maths is cool
We often discuss “non-intrusive testing” and the following is a perfect example of this philosophy using an accelerometer to determine engine power output
This test requires only one probe in the form of a TA143 3-axis accelerometer (Acc) from our NVH kit here https://www.picoauto.com/products/noise ... h-overview
The first step in the process of engine power output calculation is the acquisition of the accelerometer calibration factor (ACF). This process is automated in our Pico Diagnostics NVH software, however, for this test procedure we are using PicoScope 7 Automotive
The ACF acquisition process is very straight forward indeed and requires the X-axis of the TA259 NVH interface to be connected to a PicoScope channel (See image and text below)
ACF acquisition procedure
1. Connect the TA143 3-axis accelerometer to a TA259 NVH interface
2. Connect the X-axis output of the TA259 NVH interface to PicoScope (Above we have used channel C)
3. Set the scale of your chosen channel to x10, the input range to +- 2V (DC coupled) and a timebase of 5 sec/div (Total buffer time = 50 seconds)
4. Hold the accelerometer with the screw thread hole positioned vertically down and start recording.
5. After 20 seconds, turn the accelerometer over so that the screw thread hole is now pointing vertically up.
6. Continue recording for a further 20 seconds and then stop the capture
7. Activate lowpass filtering and set to 10 Hz for your chosen channel
6. Align both signal rulers on the captured signal as shown above and record the delta (Δ) measurement
7. Divide the Δ measurement by 2, to obtain a value typically of 0.101 mV
8. Divide 9.81 (Acceleration due to gravity) by the value obtained in Step 7 to arrive at the Accelerometer Calibration Factor (ACF)
E.g., 9.81 m/s/s / 0.101 = 97.129 m/s/s/V. (Record this value for later use)
Set-up
With the ACF acquired, attach the Acc to the driver’s seat frame, vertically with the screw thread facing forward as in the image below. We are interested in measuring the X-axis only; the fore-aft movement of the vehicle under acceleration
2. Connect the X-axis output of the TA259 NVH interface to PicoScope (In our test we have used channel C)
4. Drive the vehicle to a straight / level road and roll to a halt rather than brake to a stop. Braking will result in “nose diving” and the vehicle posture may not return to its natural ride height
5. With the vehicle at rest, start the recording but do not accelerate for approximately 5 seconds. During this period, we need to capture the DC value of the accelerometer relevant to the vehicle posture and acceleration due to gravity (This is referred to as the DC component of the accelerometer) We also use this significant value at the end of the road test to qualify the vehicle has returned to its natural ride height identified at the start of the test run. If we allow 5 seconds at the end of our test run to confirm the ride height pre and post power test we have approx. 40 seconds in our buffer to carry out a WOT acceleration test
Road-test (now for the fun part)
1. Follow all relevant safety precautions and road traffic laws
2. Do not run this test alone, one person is the designated driver who will be instructed by the laptop operator
3. If applicable, set the vehicle driving modes to Sport or “I want my mommy” mode (in the case of Tesla)
4. Turn off Traction control VSC / ESP if applicable and be aware of the implications of deactivating these systems (The vehicle will inform the driver of such)
5. With the scope running accelerate the vehicle at WOT such as to achieve maximum power at the specified rpm
6. Remember the purpose of this test is to determine the power output of the engine and so manual upshifting must take into consideration the specified rpm at which peak power is acquired (Do not upshift too early)
7. Be conscious you have 40 seconds of recoding time and during this period you will have to brake the car to near rest
8. Allow the vehicle to finally roll to a halt and note the DC component voltage of the accelerometer which will hopefully match the value obtained prior to the test run
9. Stop the scope and save your data (See below)
Above I have included a road speed math channel derived from the ABS tooth count (48 teeth per wheel revolution) to help explain the response from the accelerometer (Channel C) More information on road speed via math channels can be found here viewtopic.php?p=96821&sid=b2891430de61e ... 573#p96821
Note how the vehicle accelerates rapidly from rest (vehicle squats) where you experience that “pushed back into your seat” feeling, followed by a recovery of the vehicle posture during the upshifts
We then have an over-run period of little or no acceleration followed by a gentle increase in road speed (I may have been trying to fill the buffer with data at this point)
Finally, the brakes are applied to reduce road speed and bring the vehicle to a rolling halt.
Note how the accelerometer value at the start of the test with the vehicle at rest = 936.8 mV (DC component) does not quite match the value obtained as the vehicle rolls to rest! This may well have been due to an inclination in the road surface or, insufficient time for the ride height to return to its natural position. Where possible (to prevent errors accumulating in the math channel) try to bring the vehicle to rest in such away as to accurately match the value obtained at the start of the test run
So how do we calculate BHP from the above data?
Here is the math channel returning BHP for the accelerometer data captured on channel C above
1.341*97.129 *97.129 *1765/1000derivative(integral((C-0.9368)*integral(C-0.9368)))
Using a combination of conversions (Watts to BHP) calculus (Integral & Derivative) accelerometer calibration factor (ACF) and DC Component of the accelerometer at rest, we can graph engine power
1.341 converts Watts to BHP
97.129 (ACF^2) converts the voltage output (measured by PicoScope) into Acceleration
1765 is the weight of the vehicle during the test run (kg)
1000 converts Watts to kilowatts
“Derivative” defines to rate of change with respect to a variable (e.g., “time”)
“Integral” (area under the curve)
“C” is the PicoScope channel connected to the accelerometer
0.9368 V is the DC Component of the accelerometer (Volts)
Please do not dwell on the math’s above and except that the formula above will return engine power assuming your Channel letter (“C” above) ACF (97.129 above) DC Component (0.9368 V above) and vehicle weight (1765 kg) are accurate and entered correctly
Above we have the Power BHP math channel returning an average peak of approx. 164.5 BHP and a 0...60 mph time of 7.51 seconds
The vehicle in question is a BMW 320 d Auto X Drive Touring which is specified at 181 BHP and 0… 62 mph in 7.5 seconds; so why the difference between measured and specified BHP?
Vehicle manufacturers quote engine power based on engine dyno results and not a chassis dyno. In other words, the engine is run purely on a dyno and not connected to the transmission /vehicle. Therefore, there are no losses to account for and the true engine power output can be acquired
With our test above, the engine is subjected to load and therefore losses such as the Auto Transmission, X-Drive-train, rolling resistance of the tyres, traction loss, vehicle weight, wind resistance, road surface undulation and coefficient of drag.
As a general rule of thumb, we lose 15% of the specified engine power via the aforementioned items
Therefore: 181 BHP x 15 / 100 = 27.15 (BHP loss)
181 – 27.25 = 153.75 BHP (Expected BHP measured on the road)
The above calculation highlights the variables to consider during the road-test and the accuracy of the data entered, all of which have a huge influence on the acquired figures
Have I been a little ambitious with my peak measurement point for BHP?
Note below, peak power is 153.3 BHP in 2nd gear and appears to be an average throughout the road test (look between 4th & 5th gear) Perhaps this is a more desirable and accurate measurement point given the load on the engine will be at its greatest from rest, once we are rolling the load is reduced, however we then need to factor in wind resistance and drag
Whatever and wherever you decide to measure, keeping your road tests and measurement criteria identical will return accurate relative measurements on which to base your diagnosis and qualify any repairs. (Be mindful about variables such a vehicle weight and consider fuel level and cabin occupant weight!)
Moving onto additional measurements, below we have added engine speed via the crank sensor signal, but not using “Crank(A,60)” math channel due to the low sampling rate. (Remember math channels favor a high sample count/rate) Instead we have introduced a “Low Pass filter” into a “Frequency” math channel “(60/60LowPass(freq(A),8)” to smooth out the aliasing we see at high engine speed and therefore plot the “Trend” of the RPM which will help with the additional calculations to follow.
So why do we want to graph engine speed? Well, if we have engine speed and power, we can calculate Torque!
The formula for Torque requires engine Power to be expressed in Watts and not BHP
Engine Torque (Nm) = Power (Watts) / x ω where ω is the rotational speed in radians/s
The math channel is written as follows:
97.129*97.129*1765*derivative(integral((C-0.9368)*integral(C-0.9368)))/(60/60*(LowPass(freq(A),8)*2*3.14159/60))
The above will return engine power in Watts………
(2*π/60)*RPM will return engine speed (RPM) to angular velocity in radians per second (rad/s)
Note above the Engine Torque value obtained (292 .7 Nm) at our average peak power (153.3 BHP)
The maximum Engine Torque achieved was approx. 338 Nm with the specification being 380 Nm @ 1750-2750 rpm. Remember once again that specified Engine Torque is calculated using an engine dyno not a chassis dyno. The engine torque figures above incorporate engine power with approx. 15 % loss which of course will reduce torque by the same amount. If we add 15 % to our maximum engine torque figure of 338 NM we arrive at:
338 Nm x 15 / 100 = 50.7
338 + 50.7 = 388.7 Nm (Specification 380 Nm)
Working with the above data, it occurred to me we have engine and road speed data thanks to the crank and ABS sensor signals. If you then incorporate the differential ratio, you have transmission input and output shaft speeds and if you have these, you can calculate gear ratios!
For example: Gear ratio = Input speed (RPM) / Output speed (RPM)
Given we know engine speed (RPM) using the math channel “(60/60LowPass(freq(A),8)” we have the transmission input value ready to go.
We know road speed (MPH) using the math channel 1.03*3600/63360*2*3.1416*13.016*freq(B)/48 therefore we can modify this formula to return wheel frequency (Revolutions per second) multiply by the differential ratio (2.81) to find propshaft/transmission output frequency (Hz) and then multiply again by 60 to convert to RPM
The math channel to determine Propshaft/transmission output speed (RPM) from ABS tooth count looks like this “freq(B)/48*2.81*60”
To find gear ratios we the divide the transmission input speed by the transmission output speed by joining the above math channels together as below:
60/60*LowPass(freq(A),8)/(freq(B)/48*2.81*60)
As you can see above the gear ratios are displayed clearly except of course for 1st gear (from rest) where we have to factor in torque convertor slip and multiplication. With that said, from 2nd gear onwards the accuracy is near identical to the specifications below (ZF 8 Speed Transmission)
All-in-all the above techniques demonstrate how measuring engine Power and Torque for any vehicle (petrol, diesel or electric) can be performed in a non-intrusive fashion so providing another string to your bow during diagnosis and qualification of repair.
Please note, the tests above return a relative measurement for indication of Power and Torque and be aware of the numerous variables that can creep into the obtained results between testing. (One of which might be the weather!)
I will follow up this forum post looking at Hub Torque, Wheel Torque, and Braking Force which make for an interesting twist on the above Engine Power and Torque figures
It is mind blowing when you think we have gone from this, to this…..
To this…….
I must say a big thank you to the team here at Pico, naming Barney, Ben and Martyn and a HUGE THANK YOU to Martin Rubenstein for his assistance with this adventure that started in the summer of 2018!
- FioranoCars
- TwoWaves
Re: Maths is cool
Thanks to you and all the team for another fascinating post!
A few questions ... well what do you expect from me!
On the Pico Diagnostics tool, what are the requirements in terms of the NVH kit to get chassis dyno results? Is there a follow up (or previous?) article?
In terms of braking (and acceleration) is there any ability to discern "pull" ?
I clearly need to spend a bit more time digesting and considering the vast possibilities that this offers, but amazing stuff.
Richard
- Pico Staff Member
Re: Maths is cool
Forgive me here, I do not follow “what are the requirements in terms of the NVH kit to get chassis dyno results”
All the above test results are obtained using PicoScope and math channels and not NVH software.
The only requirement is a TA143 accelerometer and TA259 NVH interface
Just quickly skipping back through the post, I may have introduced confusion by using math’s to display gear position and then included a screen shot of the NVH “Advanced vehicle settings” dialog box from NVH.
Sorry, this was just used as a quick way to show ratio’s and I could have listed them in Excel (There is no link to the NVH software)
Regarding, “In terms of braking (and acceleration) is there any ability to discern "pull"?”
Looking at image 3 in the above post, acceleration is denoted by the fall from 0.937 V and this is what I interpret by the term “pull” (I hope I have that correct?)
Braking is denoted by the rise from 0.937 V
Once again, I hope I have interpreted your feedback correctly
Take care…..Steve
- Pico Staff Member
Re: Maths is cool
We all know that the math functions within PicoScope can unlock the potential to show you new things about the signals you acquire. From the simple A+B and A-B for CAN BUS analysis to the more advanced formulas to calculate volumetric efficiency, torque output of a starter motor and phase shift.
This post picks up on the derivative math channel that Steve used in the last post viewtopic.php?p=103173#p103173.
To quote Wikipedia the derivative can be described as -
“In mathematics, the derivative of a function of a real variable measures the sensitivity to change of the function value (output value) with respect to a change in its argument (input value). Derivatives are a fundamental tool of calculus.
For example, the derivative of the position of a moving object with respect to time is the object's velocity: this measures how quickly the position of the object changes when time advances.
For this reason, the derivative is often described as the "instantaneous rate of change.”
https://en.wikipedia.org/wiki/Derivative
If we take the example which references the derivative of a moving object with respect to time is the object's velocity and change the moving object to a sample collected by PicoScope, we can plot the rate of change between samples.
But where else could it be used?
Being at Pico I’ve been fortunate enough to spend more time looking at alternative industries outside of automotive where Pico could be used. Pico and hydraulics isn’t something new of course and with WPS600C, Pico have been supporting a number of technicians in the agricultural and construction industry and we have introduced a range of kits for use in these industries - https://www.picoauto.com/landing-page/off-highway
Hydraulics turns up in a number of different places though with industrial settings, marine, mining, aviation and even wind turbines all taking advantage of the ability to move and turn things using the power of fluid. When it comes to understanding leaks, accumulator activity and pressure spikes within a hydraulic system it’s not always the fact that a failure is caused by over pressurisation but instead how quickly that pressure change took place. It is something that I touched upon in the following post - viewtopic.php?p=101741#p101741
The principles of hydraulics can also be applied to systems like common rail diesels where we see a change in pressure as the pump pressurises the fuel before it’s delivered to the rail. There is also a change when an injection event takes place and the pressure in the rail changes again. Remember, pressure is just resistance to flow.
Below I have a capture taken from a truck where the cylinder one injection has been cut.
Channel A - Crankshaft sensor
Channel B - Camshaft sensor
Channel C - Fuel rail pressure sensor
Channel D - Cyl 1, 2 & 3 injector power supply
I’ve already included the crank math channel which shows the crankshaft slowing down which we know is on cylinder 1. Worth noting that cylinder one follows the double pulse reference on the camshaft. Always useful to know how to identify cylinders with the camshaft sensor on diesel engines!
The derivative function is quite fussy about the amount of noise a signal has. If using a 4425 or 4425A, you can make use of the floating input and reference the rail pressure signal to the sensor ground rather than the chassis ground. This does help with cleaning the signal up. Failing that, adding a lowpass filter post capture of around 1kHz will also help but it is recommended to also use a heavy low pass filter within the math channel. Typically I have found that 10Hz is enough to still have the detail required without too much interference creeping through from the original signal. Below is the derivative math channel on Channel C with no lowpass filter on either the Channel C or in the math channel.
Including the Lowpass filter for channel C, it still does not clean the math channel up.
To create the derivative math function start with selecting Math Channels (1). Click New (2) in the bottom of the pop out menu. As we need to add additional lowpass filtering, select the Filter drop down and click LowPass(3). This will automatically add the function to the formula along with the additional items required to complete the function.
As we want to apply this LowPass function, the signal part of the formula is now the derivative function. This is displayed in the scientific section as d/dx (4). This will now add the word derivative to the formula where we have to add the channel we wish to apply the math channel too. In this case it is Channel C (5).
Finally to complete the formula we have to come back to the first math channel being the LowPass filter. We have to include the cut off frequency we would like the filter to use. As I’ve said earlier, the derivative function requires a heavy filter and I’ve found 10Hz works pretty well. This will depend on the application though so more or less may be required. Click
The next window allows you to rename the math channel, change the colour and most importantly set the range. One thing you’ll notice is that units aren’t recognised by the software so it will label it with a ? This can be used as it is and really we’re looking for a visual change rather than an actual measurement.
The range may be something that takes a little trial and error. For this application I’ve found that +-10V works well (1). Finish up the math channel by clicking Finish (2).
As we know that cylinder 1 has been cut electronically, there is a lack of current flowing when cylinder one should be firing but if this was a genuine misfire situation where cylinder one was still firing, could you determine more for just these 3 signals. I have already scaled the rail pressure signal in the attempt to see if there are any fueling issues and it isn’t that easy to determine. We have some pumping element that you can see in the stepped nature of the pressure signal but it isn’t that clear. By adding in the derivative function it makes it quite clear that there is something wrong. One thing to note is that as the derivative function is the rate of change, we don’t see a lot of movement when the fuel in the rail is fairly static, not changing in either direction. I haven’t been doing this with fuel rail pressure for too long so I’m sure there will be a situation where this isn’t as clear but having another tool to use which is built into the software and doesn’t involve repeat captures can only be a good thing.
As mentioned right at the beginning of this article, hydraulics is one area where seeing this rate of change can be particularly useful. Rapid changes in hydraulic pressure can sometimes cause adverse stress on components and seals, despite the fact that the system is operating in its safe working pressures. In the image below I’ve captured the hydraulic pressure at the pump whilst a service is being activated, held on a stop to produce maximum pressure and then being released.
As expected we can see that as the service is operated we get a rapid increase in pressure as the actuator is forced to move, much like the inrush current of a starter motor. This falls slightly before increasing further as the service is held in a stop position where the full flow rate of the pump is required. As the flow has nowhere to go, the pressure rises to the system working pressure around 330 Bar. As the pressure doesn’t really change in the held position the math channel shows little movement but as the service is released from the hold, there is a rapid change in pressure as the pump is backed off to stop producing flow. This is highlighted in the derivative math channel but in the opposite direction.
Early I mentioned the rising rate values for the fuel rail pressure system don’t really have a lot of meaning. When it comes to hydraulics, this rising rate is useful, especially for designers where components are failing prematurely. We can use the measurement for rising rate to determine the change in pressure against time around one of the spikes we see when the service is operated.
With this measurement you must use the measurement between rulers as using the whole trace does not reflect the parts of the waveform that we are interested in. By selecting channel B (2) and the Rising rate measurement (3), click the measurement (4) to select the between rulers (5) and drag the time ruler to the point where the pressure ramps up and where it levels out. It should work out that it sits either side of the spike in the math channel. From the measurement we have a reading of 1,635 bar/s! Considering our working pressure is set at 330 bar, this is considerably higher! The math channel can be used as a first look but due to filtering it cannot be relied upon, it’s not far off though measuring 1,466. These types of measurements are particularly useful when it comes to proving a system component issue or a design issue.
I hope this helps and adds another math function that can provide additional information to help with understanding systems and diagnose when problems arise.
