Compression testing using the WPS500 Pressure Transducer
I wanted to share this one with you thanks to an inquiry received this week via the Help Desk.
Basically, when carrying out compression testing using the WPS500x Pressure Transducer with PicoScope 6 Automotive software, we do not incorporate a compensation feature to allow for the volume of the pressure sensor or compression hose. (Unlike Pico Diagnostics)
Such a feature becomes essential when looking at diesel compression given we add approximately 8 ml of volume to the combustion chamber!
The WPS500x internal volume = 5 ml, Pico Compression hose internal volume = 2 ml, and our dummy glow plug (volume varies depending on dummy glow plug length)
I have added a New Feature Request for the software team to evaluate but for now we can use maths to correct our values if peak pressure is what we are looking for using PicoScope software and not Pico Diagnostics.
If Peak cylinder pressure is all you require from your pressure transducer, then carrying out an Absolute Compression Test using Pico Diagnostics. Here you are only required to remove 1 x spark plug or glow plug to measure the peak compressions from all cylinders.
PD WITHOUT COMPENSATION
Included with the Absolute Compression Test is the Compensation feature that will allow for the size of the engine and volume of the measurement tool.
PD WITH COMPENSATION
When using PicoScope 6 Automotive software, to compensate for the pressure transducer and compression hose we need to calculate a multiplication factor based upon the cylinder volume, compression ratio and sensor / hose volume.
The captures included in this post were taken from a Vauxhall Astra Diesel, 1.7 Litre, 4 cylinder engine with a compression ratio of 18:1 using a sensor volume of 7 ml (Transducer and hose)
Compensation formula required when using the WPS500x Pressure Transducer to measure peak cylinder pressure with PicoScope 6 Automotive software:
Cylinder displacement / (Compression Ratio -1) = Combustion chamber volume
Combustion chamber volume + Sensor volume / Combustion chamber volume = Multiplication Factor
The Multiplication factor is then used to multiply the pressure results obtained by WPS500x
4 Cylinder engine displacement 1686 cc Compression ratio 18:1
1686 / 4 = 421.50 (Displacement per cylinder)
421.50 cc / (18 -1) = 24.79 cc (Combustion chamber volume)
24.79 cc + 7 cc / 24.79 cc = 1.28
1.28 is the Multiplication factor required to correct peak cylinder pressure.
Multiplication factor x Obtained pressure = Correct Cylinder pressure allowing for the Pressure Transducer and Hose
Math Channel for WPS cylinder pressure captured on channel B
Pressure x Multiplication factor = B X 1.28
MATH CHANNEL FORMULA
Temperature will also effect our compensation values and can be incorporated into alternative formulas if required
Here we now have the corrected cylinder pressure value.
PS WITH AND WITHOUT COMPENSATION
Using the same engine and cylinder above only now with a compression gauge we can see just how challenging cylinder measurements can be as a conventional gauge reads approx. 32.5 bar pressure! Why?
CONVENTIONAL GAUGE
CONVENTIONAL GAUGE
Here cylinder pressure is repeatedly captured and “built upon” by numerous rotations of the engine.
A conventional compression gauge adapter will contain a Schrader valve where the pressure is not allowed to escape and so often, we can convince ourselves a compression is good by holding onto the starter motor for prolonged periods to “build” our low compression to a decent compression.
With the Pico Scope software we obtain a clean measurement sweep of the cylinder as the Pico compression hose does not contain a Schrader valve so allowing peak compression to decay during the Expansion Stroke.
Here we can measure the ability of a cylinder to generate sufficient compression from a single stroke only whilst comparing this ability to neighbouring cylinders. Over and above peak compression is the ability of PicoScope to evaluate the four stroke cycle for timing and breathing ability of the engine.
To conclude here, for peak compression of all cylinders (using one cylinder only) use the Pico Diagnostics software with the compensation feature (Absolute Compression Test) and use PicoScope to discover why peak compressions are low based on 4 stroke anomalies.
Re: Compression testing using the WPS500 Pressure Transducer
Post by STC »
Hi Steve
In the interim here is a MS Excel Spread sheet I have tapped up. Hope it can fill the gap.
Compression Variation.xlsx
(10.99 KiB) Downloaded 956 times
(it is not locked so improve / alter it as you wish)
Hope it helps !!!
Nice work STC thank you.
I will keep this to hand myself and no doubt this will help many others too.
Take care.......Steve
volrem
Post by volrem »
Steve Smith wrote: The WPS500x internal volume = 5 ml,
Steve,
Where does this value come from? So far I have used 1,5 ml in my calculations. I got this value using syringe method.
Can you confirm that 5ml is indeed correct and therefore it's not possible to measure it correctly with syringe?
I rechecked it and still got volume of 1,5 to 2 ml.
Post by STC »
Hi Volrem
I saw that too some time ago.
Steve may know something that we don't ... but I thought that was a typo.
Perhaps that should read The WPS500x internal volume = 2 ml, Pico Compression hose internal volume = 5 ml ? I'm not certain on that neither am I able to measure that right now. Perhaps you could confirm or correct me.
Thanks for the feedback an sorry for the mega late reply.
You are most certainly correct re the internal volume of the pressure transducer and hose, this was my mistake.
The following forum post will hopefully clear this up topic21311.html?&p=97815#p97815
The pressure transducer internal volume is approx. 1.22 mL and the compression hose is approx. 2.0 mL
Thanks again as always for the feedback, take care......Steve
victor2k
Post by victor2k »
The pressure sensor can't be used in 6.13.14 PicoDiagnostics(Pressure button not open the settings window),only relative compression can be measured. :(
Best regards
Hello Victor2k,
Thank you for bringing this to our attention. I have notified the software team and rest assured it will be looked into asap.
victor2k
Post by victor2k »
Also the result of relative compression does not reflect the truth.I compared the battery voltage drop to compress the air and I found:71%,91%,85%,100%:
Toyota_Avensis_2004_Diesel_20190108-0001.psdata
(485.31 KiB) Downloaded 633 times
Here is the relative compression
190104_CompressionTest_001.rar
(83.34 KiB) Downloaded 545 times
And here is the measurement of pressure in cyl 1-2-3(glow plug broken at cylinder 4 can't be removed),excesive compression at cyl 2(and cyl 4 according to the battery voltage drop) because of the excesive oil consumption of engine
Toyota_Avensis_2004_Diesel_20190105-0001.psdata
(318.97 KiB) Downloaded 620 times
Using an older version of PicoDiagnostics I have the same strange result(2628kPa/381PSI is specified by manufacturer).I can't upload .pddata file,I use .rar to attach it :?:
140610_CompressionTest_001.rar
(89.65 KiB) Downloaded 567 times
victor2k
Post by victor2k »
I have some bad news...today I tested again PicoDiagnostics/Compression Test with the glow plugs removed from cyl 2,3,4 and please see the result
190110_CompressionTest_001.rar
(84.02 KiB) Downloaded 571 times
Attached is also the battery voltage and starter current in the same situation
Toyota_Avensis_2006_Diesel_20190110-0002.psdata
(1.58 MiB) Downloaded 659 times
so is not a recording issue :?
Here is the measured compression
Toyota_Avensis_2006_Diesel_20190110-0005.psdata
(1.63 MiB) Downloaded 642 times
Best regards
