Fiat Doblo 1.6 Diesel worn camshaft
ktl2019
Post by ktl2019 »
Hello
This Fiat smokes white (unburned diesel) and jerks when accelerating.
According to the injection quantity deviation, it affects the 2nd cylinder.
Compression on all cylinders is between 20 and 21 bar. (little low but engine starts and run)
Pressure loss test on all cylinders between 5 and 10 %
When injectors 1 and 2 are swapped, the error does not move
I have now measured the intake manifold pressure with a piezo pressure sensor and the current consumption of the first cylinder with a piezo pressure sensor.
But can someone explain this waveform, how can i identify the worn camshaft of the 2. cylinder
Made this test the first time.
My english is very bad, have translated this with google translator.
Maybe one guy here also speak german and can explain it.
Muju Fiat Doblo Saugrohrdruck + Injektor 1.psdata
(9.31 MiB) Downloaded 48 times
ktl2019
Re: Fiat Doblo 1.6 Diesel worn camshaft
Post by ktl2019 »
I created a primitive table, hope it's correct
Muju Fiat Arbeitsspiel.pdf
(56.04 KiB) Downloaded 82 times
Littlejohn
Post by Littlejohn »
it’s a great capture.
Looking at it I am surprised you had good compression as it looks like there is no intake pull at all.
Do you have a wps to go in-cylinder?
ktl2019
Post by ktl2019 »
Dont have a WPS, but will order a PDS500G
In idle i runs fine if engine is a little be warm, but smokes white
