2008 Subaru outback 2.5 na
- Attachments
- Subaru_Legacy Outback_2008_Petrol_primary ignition 1 frame.psdata
- primary ignition connected to primary ground and battery ground 10-1 attenuation
- (226.38 KiB) Downloaded 30 times
Re: 2008 Subaru outback 2.5 na
If we are talking about the SUBARU EJ25, then a dual coil with a dual ignition switch is installed.
The ignition switch is controlled by applying a rectangular pulse with an amplitude of about +8.4 volts.
When using a 1:10 divider, a signal with an amplitude of +0.84 volts is obtained.
so this is what kind of wave form I'm getting from my primary ignition connected to battery negative and primary coil negative and it does have the coil pack
