Alfa mito 1.3 it’d injector current
eldog79
Post by eldog79 »
Hi I’m looking at injector current and the tops are not looking right and wondering what this means
All 4 doing this and got fault codes relating to injector a curcuit open and short
IMG_3505.MOV
(8.04 MiB) Downloaded 80 times
Re: Alfa mito 1.3 it’d injector current
Regarding the fault codes, could you post those DTC’s here?
Beyond the fault codes, what are the customer symptoms, i.e., does the vehicle perform OK, do we have any smoke via the exhaust or excessive diesel knock/rattle?
How is the starting performance hot/cold? (Good crank and start or prolonged cranking)
Whilst on the road at cruising, can you feel a misfire or momentary hesitation?
Does the vehicle break down and fail to start?
Would you have the psdata file from the video?
If so, could you post here so I can review the set up
Sorry for all the questions, this will however help with the diagnosis
Take care…..Steve
