2012 BMW X5 35d M57 diesel
Hberwald
Post by Hberwald »
Crank no start/stall. Error codes show bank 2 injectors disabled. It will start, run for a couple seconds and then the DME shuts down the fuel.
I have replaced the injectors, had the DME tested on another car, and all is good.
I believe I am loosing fuel pressure. Data PID shows that the fuel pump is running at about 75% of requested speed. Wondering if I have a bad pump rotor winding as no fuel pump codes present.
I don't want to throw parts, like the HPFP and Pressure sensors, volume control valve, etc.
Any collective thoughts?
BMW_X5_2012_Diesel_20230707-0002.psdata
(4.64 MiB) Downloaded 190 times
