Hi to everyone, I'm a newbie when it comes to using an oscilloscope, I have been working on Ford fiesta 1.6tdci mk7 with Bosch solenoid Injectors for many many months with very little success. Symptoms are uneven idle not from cold but after it's running for 5-10 minutes, Using my picoscope I have three pulses which I believe to be pre Injector, pilot and then main from a cold start but as it warms up I get random pulses which is causing the rough running, the strange thing is when I switch on lights heaters etc the pulse return to normal and so does the running. Injectors have been replaced twice check voltages and earths to ECU injector wiring various sensors and wires, any help or suggestions would be greatly appreciated
Regards Paul
Check the ckp signal against cyl 1 for reference, ckp tone rings are very troublesome and the magnets do seem to loose strength over time.
Might also be worth disconnecting the alternator and seeing if your symptoms are still apparent ( just put the battery on a support unit whilst testing) this would eliminate any EMF from the alternator effecting the injector solenoids
Danny
Hi GGS,
This is interesting, it could be helpful to others in this forum.
Would you have some .psdata files to share with us? Like before with bad ECU and fixed with new ECU for example?
If so, please upload.
Thank you for update.
Roman
