Fail to connect with CAN test box
We tried to measure the OBD directly but still didn't work. We also check that Odyssey is parallel connection, so there should be no need to activate the gateway.
- Pico Staff Member
Re: Fail to connect with CAN test box
I think in this instance it would be good to attach a scan tool to the CAN test box and access the vehicle. It looks very much like the VW network where there is no communication till a request is made.
If the test box and the scope detect CAN on another vehicle things are pointing towards the vehicle side.
Let us know how you get on.
