Pressure sensor to detect spark voltage leak
V8 doing in Cylinder pressure testing, noted strange drop out of pressure, occurring at the same time on every pulse. Checked battery and ground power to sensor - both consistent at time of drop out so what the heck is going on ? Only when I looked at the COP sync and used the rulers to split into 8 did I notice that the drop out's were linked to coil firing
Then I realised that in order to avoid issues with hose removal I had used a threaded metal tube to link sensor to plug hole, so what I was seeing (I think) was the sensor shutting down as stray voltage from a coil grounding outside of the plug. Going to electrically isolate sensor from test tube in future as I'm sure it will not do my expensive scope any favours.
- but it does make me think about using a COP sensor on an earth at the cylinder head!
