Exceeding the specified current of a current probe
Tomblueprintauto
Post by Tomblueprintauto »
If the 60 amp current probe was left on the main battery cable during cranking, would this induce enough voltage in the probe to damage it?
Re: Exceeding the specified current of a current probe
Post by liviu2004 »
I don’t think so, we talk about mV and each coil has a magnetic saturation limit.
jueja
Post by jueja »
The 60 amp probe will survive this....Actually its reading will max out around 200 amps and these readings are pretty accurate and in line with the measurements of a high current clamp. If you wanted to avoid the signal from the 60A clamp being clipped off than you may want to ac-couple it.
