Number of current clamps simultaneously
sandeep
Post by sandeep »
how many current clamps can be used at a time ?
i need to capture three signals (Fuel injector signals) simultaneously but i am facing an issue that i can able to caputre not more than two simultaneously using Picoscope 6 Automotive software.
Am i missing anything in settings or..., Help me.
Re: Number of current clamps simultaneously
Hello Sandeep and thank you for the post
There is no limit to the amount of current clamps you can use with your scope (Using PS6 or PS7)
If you have 4 channels then you can use 4 current clamps
Could I ask, which PicoScope are you using and what issues are you experiencing?
Could you provide a screen shot or psdata file demonstrating the concern you have?
Just as a "Tip" for capturing Fuel injector signals, if they share the same power supply via a single fuse, you could use 1 current clamp placed around our fuse break out lead to capture all fuel injector current "ramps" with a single clamp and scope channel
