intermittent cut out while driving
Kudugar
Post by Kudugar »
HI All, i have isuzu nqr500 truck with 4hk engine, while driving intermittently it cuts out momentarily. i scoped the crank sensor as i tested while stationary and doing wiggle test on wiring. this is ac signal received from sensor but varies from factory as it does not seem to have sufficient + voltage above zero line and not getting pulse as per factory sample? please review and give your thoughts?
nqr500 Isuzu_2008_Diesel_20210421-0001.psdata
(4.69 MiB) Downloaded 579 times
