Opel Astra crank sensor
Audi88
Post by Audi88 »
Opel_Astra H crank upload.psdata
(8.99 MiB) Downloaded 323 times
I got this waveform from a Opel Astra 2005 engine XEP16. problem is long crank time P0300 random misfire
I can tell it is not right, but is my connection right one lead to signal wire Brown and the other lead to battery Ground (earth)
Audi88
Re: Opel Astra crank sensor
Post by Audi88 »
I went back to the car and put both leads on the sensor. I had 1,32V on both wires unplugged.
Opel_Astra H_crank-sensor-100ks.psdata
(2.78 MiB) Downloaded 302 times
Most certainly I would examine the crankshaft sensor pick up ring based on the shape of the waveform at the "reference point" (Missing teeth)
This is where the waveform library comes into its own and where we must thank LucaB for his contribution
Please take a look at Bens video here https://www.picoauto.com/library/waveform-library on how to access the waveform library using PS6 at present (PS7 coming soon)
Below we have the Waveform Library in action:
Here we can see how the loaded crank signal (Red) from the Waveform Library differs to yours (Blue)
I think it would also be helpful to compare LucaB cam and crank signal with your own for any possible correlation issues
The following links will help:
topic18471.html
topic21754-10.html
Audi88
Post by Audi88 »
perfect thanks :D
Audi88
Post by Audi88 »
Here is a picture of the missing tooth, it is no damage to the reluctor wheel but my first thought when I saw the waveform it was a misaligned sensor but it is not possible. Hopefully, I get the sensor before Christmas
This:
Or they used aftermarket parts.
Audi88
Post by Audi88 »
Car starts feel great, I also have 02 sensor slow response no code for the sensor but I have lean codes.
With 160.000 km new oxygen sensor needed.
Audi88
Post by Audi88 »
Car fixed with the crank sensor but now is the misfire still there freeze frame data show random misfire cyl 4 setting the code at 1900 rpm engine temp 65 C here is a file with amp clamp on all injectors and primary injector voltage cyl 4 this look suspect.
misfire.psdata
(5.66 MiB) Downloaded 300 times
Haven’t seen waveform but these engines are notorious to misfire random when intake egr channels are dirt blocked there is even an tsb for. Take egr plug out clear codes test again.
