Just got a scope. What software?
Thanks,
John
Re: Just got a scope. What software?
The OEM hardware is normally locked to a specific OEM software and the standard general release SW will not usually work with your hardware.
Your dealer tech support should be your first port of call.
Kev.
- Pico Staff Member
PACCAR Tech support would be your first port of call for a 4425-44 device but a 4425 - 013 is for a DAF Scope.
The DAF device should may run the Generic version of PicoScope 6 Automotive which you can download here:
https://www.picoauto.com/downloads
If this fails to recognize the device then it would be DAF technical support who can assist you further
I hope this helps, take care....Steve
//Kristoffer
- Pico Staff Member
A -031 variant of scope is actually a Toyota scope and as such it won't function with the generic software. For this reason you will need the approved Toyota software.
For this you would have to speak with the regional Toyota technical team to see how you might obtain the software.
Hope this helps.
