Hello ... i just bought a pico 4425 with almost all accesoriess... and start learning... and i am a beginner ^^...
I saw that i need PP943 ( Complete 6-way universal breakout lead kit ) and i ordered it...for some sensors.
My question is... is this PP943 enough for measuring voltage and amps for fuel injectors? or do i need to order specific breakout leads for acurate measuring? like TA230, TA012, TA267, TA192 .... etc... ?
Thank you
Thank you for your post. You're not alone on this journey so please feel free to post and comment here on the forum for advice and support.
I've used the PP943 leads for injectors and they work fine. You do have to be very mindful though to make sure the pins are in the correct terminal otherwise there is a danger of short circuits. This is where the designated breakout leads work better as they eliminate any chance of getting this wrong and also prevent any unwanted disconnection if you wish to perform a road test.
