NVH Microphone connection and set up options
Customer complaints of noise (e.g. transmission whine & brake squeal) require the addition of a microphone in order to capture and display the frequencies relevant to the customer concern
How do I add a microphone to capture noise if only one NVH interface is available? (3 channel TA259 or Single channel TA148)
One, single channel interface connection (TA148)
Open Pico Diagnostics and Click on NVH
Select Start a new test and choose how to obtain RPM (Typically J2534 or J1939 with engine on)
Image 1
Image 1
Click Next and ensure the engine RPM is displayed correctly
Continue to follow the Setup Wizard and enter Engine configuration, Cylinder count, Drivetrain arrangement, Differential ratio & Tyre size
Select the style of NVH Interface required, Single or 3 Channel. (Single in this example)
Image 2
Image 2
Selecting a single channel interface will allow you to choose the type of sensor you wish to connect.
Click on the Dropdown arrow and select TA144 Microphone and select Next
Image 3
Image 3
4 MIC SETTING.png (11.17 KiB) Viewed 11849 times
Connect the Microphone to the single channel interface and connect the interface to Channel B of PicoScope
Image 4
Image 4
Mount the microphone in a vertical orientation in close proximity to the drivers head/ear (assuming the driver is the complainer) Click Next and Finish
Before selecting “Start Recording” click on the Setup tab
Check the response of the Microphone by clapping your hands in close proximity to the mic. The response of the microphone will be displayed in the Signal Bar
Image 5
Image 5
Select the location of the microphones (Passenger or Engine compartment) and include notes on the precise location of the mic
Click on the Options tab and select Advanced Options
Choose the Maximum frequency of interest (20,000 Hz will enable the entire human audio spectrum to be displayed)
Select the frequency units (Hz) and the desired Sound Pressure Level (SPL) weighting, click on OK
Image 6
Image 6
Select the Record and Analyse Tab followed by Start Recording
Note: The microphone will now be recording all sounds in the vicinity of the mic where you may choose to narrate along side “noise” complaints for reference during playback
One, 3 channel interface connection (TA259)
Image 7
Image 7
Select the style of NVH Interface required, Single or 3 Channel. (3 Channel in this example)
Image 8
Image 8
Select the 3 channel interface option and click Cancel, this will return you to the Setup screen
Select the drop down arrow adjacent to the “Mode” option and choose Single Channel
Image 9
Image 9
Change the “Box” field to TA259/TA366 (Sum) Interface
Select “Sensor” TA144 Microphone
Connect the Microphone to the 3 channel interface and connect the interface to Channel B of PicoScope (You can use any of the 3 channels of the 3 channel interface)
Image 10
Image 10
Image 11
Image 11
If two NVH interfaces are available (Any combination of 3 channel interface (TA259) or Single channel interface (TA148)
The following connection method is the most desirable “setup” for the majority of NVH complaints as we now combine a microphone with an accelerometer using 2 NVH interfaces to capture NVH from 0 Hz - 20 kHz
Image 12
Image 12
Regardless of the interface chosen, ensure the selected sensor is a TA143 Accelerometer. (This is the default sensor when selecting a 3 channel interface)
Continue to follow the Wizard through to completion and click on “Finish”
Click on the Setup tab and follow the relevant procedure below:
When using a single channel interface for your initially connected accelerometer (Channel B)
Change the Vibration Signal Mode to “Multiple sensors
Ensure the number of interfaces indicates “2”
Change the “Box” field for sensor 1 (Channel A) to either a 3 channel interface (TA259) or single channel interface (TA148) depending on the interface you are using
Select “Sensor” TA144 Microphone for sensor 1
Connect the Microphone to the chosen interface and connect the interface to Channel A of PicoScope (If using a 3 channel interface you can use any of the 3 channels)
Ensure the “Box” field for sensor 2 (Channel B) is set to use a single channel interface (TA148)
Select “Sensor” TA143 Accelerometer for sensor 2
Mount the Accelerometer in the relevant orientation at the desired location
Check the response of the Accelerometer by tapping the mounting point in close proximity to the accelerometer. The response will be displayed in the Signal Bar
Select the location of the accelerometer (Passenger or Engine compartment) and include notes on the precise location and orientation
Image 13
Image 13
When using a 3 channel interface for your initially connected accelerometer (Channel A, B & C)
Change the Vibration Signal Mode to “3-Axis plus single channel
Ensure the “Box” field for sensor 1 (Channels A, B, & C) are set to use a 3 channel interface TA259. (This will be set by default)
Select “Sensor” TA143 Accelerometer for sensor 1 (This will be set by default)
Ensure the “Box” field for sensor 2 (Channel D) is set to either a 3 channel interface (TA259) or single channel interface (TA148) depending on the interface you are using
Select “Sensor” TA144 Microphone for sensor 2
Connect the Microphone to the chosen interface and connect the interface to Channel D of PicoScope (If using a 3 channel interface you can use any of the 3 channels)
Select the location of the microphone (Passenger or Engine compartment) and include notes on the precise location of the mic
Image 14
Image 14
Image 15
Image 15
I hope the above helps with the application of Microphones within NVH using an array of interfaces.
Generally speaking, the TA259 3 channel Interface will be the most popular device used with our NVH software, however for those who have the TA148 single channel interface this can also be utilized as described above
Calek
Re: NVH Microphone connection and set up options
Post by Calek »
What is the maximum sound acquirable from micropohone? if the sound over exceeds its limit, could i see something on other harmonics?
Hello and thank you for the post, sorry for the late reply
NVH utilizes an maximum input range for the microphone of +- 2 V when using the 60-125 dB range
Image 1
Image 1
With your microphone set up as above, the maximum range permissible within the NVH signal history is +- 40 Pa
Above this level the data will be clipped and the reproduced sound appear "over modulated"
As a experiment, we could use a signal generator with a sine wave output exceeding 2 V (e.g 2.5 V+)
This signal could then be fed into our NVH software via the relevant channel (i.e. the channel set up as a microphone)
Here we could capture all the relevant harmonics associated with this over-range condition
I will try to set this experiment up but it will not be any time soon (sorry)
