PicoScope 7 Automotive
Available for Windows, Mac, and Linux, the next evolution of our diagnostic scope software is now available.
There is your opportunity! Every time you fit a new one, scope it to within an inch of it's life. that way you will get to see the differences between the faulty one that you tested to start with, and the new shiney one you replaced it with.
Look at what it is commanded to do and what it is doing.
Using the ACC is a good way to do the test but not the Best !!Ok so how fast should I expect to see a change in fuel pressure once a higher duty/ demand from acc pedal is applied?
