NISSAN juke C1130 fault code
Re: NISSAN juke C1130 fault code
I have had this lots of times even using Nissan diagnostic software.
For me though the fault clears and has not returned but with a non Nissan tool it won’t shift. The pipe your talking about was that in relation to DPF? Nissan have in the past used the esp or 4wd lamps when there is a problem in the diesel system!
Sorry it’s not much help but just thought I would give you a heads up on my experience.
Iv has many of these problems on the Nissan jukes and that code is related to a engine fault weird I know.
What I found is that it is always the pipe or the banjo bolt blocked going to a pressure sensor. It’s the one at the top of the engine with a small piece of rubber pipe going on to a metal pipe then dissapeares behind the manifold, it’s bolted to the manifold or the head (can’t remember) with a banjo bolt.
Hope this makes sense and helps
Mike.
- Newbie
