Filtering
tonyswain50
Filtering
Post by tonyswain50 »
Hi i'm not sure if this an issue with my Pico unit itself (4423) or normal but when i activate filtering to clean up a signal it only takes effect at the end of a sweep or if i freeze the image but not whilst running ( hope that makes sense ) am i not able to view a filtered signal while running or is there something in settings.
Thanks Tony
Re: Filtering
Post by Martyn »
That's normal, filtering is only performed when the sweep has completed.
Re: Filtering
Post by Autonerdz »
I suggest that you only use filtering AFTER the capture is made and scope stopped or on a saved capture.
There is no reason to run live with a filter anyway and it can reduce performance.
tonyswain50
Re: Filtering
Thanks for the replies that clears that up .
Cheers Tony
