rolling back action fault
MAE
Post by MAE » Thu Aug 06, 2015 9:51 pm
I have had pico automotive working fine on this computer. This morning i loaded the program and it popped up with an update available. So i clicked on update and when it was done pico was not on my computer anymore???
I went to the web site and reinstalled the program but as it is installing it comes up in the install bar "rolling back action" and takes everything off?? I tried the beta release and same thing happened. please help
Re: rolling back action fault
Post by Steve Smith » Fri Aug 07, 2015 9:26 am
This is disappointing for sure, could you try the following for me?
Ensure both PicoScope versions are uninstalled (Beta and Stable)
We then need to delete the contents of the following folders
Windows XP: C:\Documents and Settings\\Local Settings\Application Data\Pico Technology\
Windows Vista/7/8: C:\Users\\AppData\Local\Pico Technology\
The example below is for Windows 8
Could you then locate the the folders in the images below?
I would like you to delete the contents of these folders (Not the folders themselves)
Could you then try to reinstall the stable version only?
Should the install prove unsuccessful, could you create an install log file and send these over to support@picotech.com
To create an install log file please take a look here at topic10701.html
Sorry for all this additional work but we will resolve this for you
Take care......Steve
MAE
Post by MAE » Thu Aug 13, 2015 8:23 am
ok i deleted the files as suggested and tried to reinstall, no luck same fault. I noticed i still had the old install file on the computer "picoscope6automotive_r6_10_11" in my downloads folder, so it tried that one and it installed first go no problem
MAE
Post by MAE » Thu Aug 13, 2015 8:36 am
ihave just done the beta install and recorded the log, i have sent the files through email
Post by Steve Smith » Thu Aug 13, 2015 11:58 am
Hello and thank you for your patience and input here.
I have filed a bug report and sent this over to the software team
I will feedback as soon as possible.
crackerclicker
Post by crackerclicker » Sat Aug 15, 2015 1:40 am
Wasn't there a warning somewhere about updating to 6.10.16 if you had an older version before trying to load the Beta?
Post by Steve Smith » Tue Oct 06, 2015 3:53 pm
Many thanks again for your patience on this matter surrounding updates.
This issue has been addressed and will be under-test for a beta build a soon as possible.
In the meantime there is a work around thanks to our colleagues in both the UK and US (Thank you again)
The temporary fix surrounds disabling Driver Signature Verification until you install the software.
For an explanation on How To could you visits the link below?
http://www.howtogeek.com/167723/how-to- ... d-drivers/
"You shouldn't have to do this, as long as the computer has the latest Windows updates installed for Windows 8.1 however - there might be an issue with how one of the updates was installed".
Once again a big thank you to all involved with the information above and the new up and coming beta build
Any feedback would be most appreciated, take care.......Steve
Post by Autonerdz » Thu Oct 15, 2015 3:33 pm
Steve,
In our experience only Asus PCs are affected. Specifically tablet models.
Has this been your experience as well? If so, why only Asus?
Post by Steve Smith » Fri Oct 16, 2015 9:29 am
Thanks for the heads up re ASUS.
Not sure if this is the case as there are reports of Toshiba Encore 2 (Tablet) with identical symptoms.
As soon as the new Beta build is available we can get to work with these machines.
Joller79
Post by Joller79 » Mon Oct 19, 2015 4:20 pm
Finally i found this thread.
I got a asus t100 hybrid tablet/laptop.
That installs pico 6 non auto. Just fine, but the automotive one, does this thing and rolls back?? What to do, im currently upgraded to win 10. It is 32 bit version. Any idea??
Cheers
Johan
