Timing Check
JOE TECH
Timing Check
Post by JOE TECH » Wed Oct 22, 2014 8:41 pm
Got a MITSUBISHI SHOGUN 3.2 DIESEL 2008 Not start in workshop
Have taken compression test with pico (major fault)
Can anybody help with cam+crank scope test as I suspect timing chain has jumped
Thanks Joe
hijakd
Re: Timing Check
Post by hijakd » Thu Oct 23, 2014 8:50 am
Hi just locate your cam and crank sensors and put them on two separate channels then have a look at the wave form,u may struggle if you don't have a good known wave form
Re: Timing Check
Post by Steve Smith » Thu Oct 23, 2014 10:55 am
Hello Joe Tech and thank you both for the posts.
I have just taken a look at the Waveform Library but no joy for a comparison.
Can anyone upload such a waveform if possible to the waveform library?
From here Joe Tech you can then download a running example. Good luck and thank you for the appeal
Take care......Steve
