Pico In Cylinder for the win
- OneWave
If you look closely you will notice spark is about 81 degrees from TDC. That is almost a cylinder off. So we reviewed our plug wire set up again. And confirmed it through 3 sources as well as multiple people saying we were right. when you looked at rotor it did not see to be in right position.
so to prove the point we moved the spark plug wires by 1 cylinder on the distributor cap. That is the second capture\screen shot you see. The truck started right up. So that tells me the original owner or his mechanic has messed with the distributor and it is off by a tooth or 2.
Would never have found it without the PICO and the Phad transducer.
