Skoda Yeti 2011 rough running, lack of power and smoke
bmtech
Post by bmtech »
Hello...
Need help from experts here.
Car came in with plugged up DPF with heavy carbon deposits in the exhaust and turbo. Trouble codes were - P0299, P046C,P0121, 7934,P00AF. Before coming to my garage, the HP pump and injector units were serviced by another garage.
Complete exhaust cleaned and DPF decarbed, Turbo serviced, Cyl head reconditioned, and commissioned the engine. Spewed lot of carbon out initially and cleared. But engine still runs on low power, smoke. Test driven for more than 30kms. No trouble codes!
Boost actuator working, MAF responding well.
Scoped injectors at idle and 2500 rpm. Did not like them. Kindly have a look and share what you think.
Thanks.
__20190409-0001 cyl 3 2500.psdata
(1.22 MiB) Downloaded 448 times
__20190409-0001 cyl 2 idle.psdata
(1.26 MiB) Downloaded 445 times
__20190409-0001 cyl 2 idle 3.psdata
(1.23 MiB) Downloaded 412 times
__20190409-0001 cyl 2 idle 2.psdata
(1.23 MiB) Downloaded 419 times
__20190409-0001 cyl 2 2500.psdata
(1.27 MiB) Downloaded 411 times
__20190409-0001 4 cyl idle2.psdata
(1.38 MiB) Downloaded 423 times
20190409-0001 cyl1 idle.psdata
(1.22 MiB) Downloaded 433 times
20190409-0001 cyl1 idle 2.psdata
(1.24 MiB) Downloaded 407 times
20190409-0001 cyl 1 2500.psdata
(1.25 MiB) Downloaded 448 times
__20190409-0001cyl 4 idle.psdata
(1.26 MiB) Downloaded 405 times
__20190409-0001 cyl4 idle3.psdata
(1.2 MiB) Downloaded 411 times
__20190409-0001 cyl 2500.psdata
(1.25 MiB) Downloaded 402 times
__20190409-0001 cyl 4 2500.psdata
(1.28 MiB) Downloaded 431 times
__20190409-0001 cyl 3 idle.psdata
(1.22 MiB) Downloaded 408 times
(1.22 MiB) Downloaded 437 times
(1.26 MiB) Downloaded 425 times
(1.23 MiB) Downloaded 437 times
(1.23 MiB) Downloaded 388 times
(1.27 MiB) Downloaded 395 times
(1.38 MiB) Downloaded 374 times
Re: Skoda Yeti 2011 rough running, lack of power and smoke
Post by KimAndersen »
Hi.
Is it black smoke coming from the tailpipe ! If that's the case I would be looking at the MAF sensor and this is despite your comment.
You should check the specified vs actual values from the maf sensor it could be reading a high MAF value.
The diesel particle filter is cleaned and my first thought was if the ash level should be reset or not. I know when the DPF is changed for new, it should be reset !!!.
Kim
seafordmotors
Post by seafordmotors »
Firstly if yoy have black smoke coming out of any diesel equipped with a DPF or the tailipe is black than you
the DPF is damaged and needs to be replaced. No cleaning will restore a damaged DPF.
Also look at the boost control and EGR operation.
