Ignition trace query
roadandtrack
Post by roadandtrack »
i am attempting to identify poor/erratic running with a Toyota 4AG race engine using a Motec M4 computer. Almost every part on an around the engine is new, yet i have erratic operation which is sometimes on 1 cylinder and then it moves to another cylinder. i am using exhaust temperatures to work out which cylinder is not working properly. i have done extensive mechanical tests and ruled out problems from that source
i have been unable to work out how to make the scope view all 4 cylinders at the same time and separate the signals as they all seem to be vertically beneath each other??. is there a fix for this??
I attach various traces of the secondary ignition where i have changed the ignition coil as i suspected that as being part of the problem . i nearly all cases, the voltage rises. can anyone offer some plausible explanation for this?
many thanks, Terry
bosch transformer coil cyl4.psdata
(19.2 KiB) Downloaded 450 times
generic oil filled coil cyl2.psdata
(16.9 KiB) Downloaded 425 times
speck
Re: Ignition trace query
Post by speck »
How about turn your no.of samples up and put some more time on the screen. 500ms/div -500MS
and repeat
speck
Post by speck »
speck wrote:How about turn your no.of samples up and put some more time on the screen. 500ms/div -500MS
and repeat
5MS sorry
roadandtrack
thanks, if you open the files you can move back and forth
yes, i can try logging for longer
speck
Post by speck »
roadandtrack wrote:thanks, if you open the files you can move back and forth
yes I know. Your settings are poor. Also include primary current.
roadandtrack
define "primary current" please so i can make sure i'm logging what you expect
speck
Post by speck »
roadandtrack wrote:define "primary current" please so i can make sure i'm logging what you expect
How about looking it up in "guided tests"
roadandtrack
here are some files. any help appreciated
what i can see is...
voltage varies a lot across all 4 cylinders despite having all new parts and plugs with identical gaps. changing coils increases the peak, but still i get this big variation. engine compressions are all identical
i changed the coil saturation time from 3 to 6 msec and that got it up to about 6amps and increased the peak voltage output. engine sounded better but still randomly not running nicely on all 4.
cylinder3.psdata
(8.95 MiB) Downloaded 421 times
Coil Curent and Coil Sec motec DELL=6 3000rpm engine sounds like 3 cylinders.psdata
(10.22 MiB) Downloaded 408 times
speck
Post by speck »
roadandtrack wrote:here are some files. any help appreciated
