Mack/Volvo MP8/D13 delphi injector current ramp
Mathis3521
Post by Mathis3521 »
has anyone on here ever done a current ramp test on Mack MP8 or Volvo D13 injectors? they want you to test voltage common (bank fired) to injector signal (pull to ground). however I would like to test the current ramp on these injectors in the case of a voltage signal check not showing me what I want to see which is actual injector performance. if anyone has ever done this test or anything similar I would like to see what the wave form should or should not look like. any advice would be much appreciated.
ronw38
Re: Mack/Volvo MP8/D13 delphi injector current ramp
Post by ronw38 »
Hi try Pico help , select Online Documentation , select Actuators , select Injectors [diesel] select make , select voltage or current tests this will guide your procedure. Cheers Ron
lastvagn8
Post by lastvagn8 »
Hi Mathis,
Did you solve the problem? Im interested in the solution if you have it. :) Since it is 4-wires to the injector, I never tried them.
TonyTools
Post by TonyTools »
Hi Mathis
I’m interested in how you got on and have you got any reading, do a lot of Volvo diagnostics. Will be trying to scope injectors next week on a intermittent injector fault on a Volvo FM D11 engine. Same type of injector.
Sharpy
Post by Sharpy »
TonyTools wrote:
Sun May 03, 2020 5:30 pm
Hi Mathis
What age is the Volvo? I have some injector current captures mostly for the euro 6s as the older ones didn't give as much bother.
