Ruler settings not showing
rudolf
Post by rudolf »
Hello.
I saw in demonstrational videos and guides that one can set the number of rulers, like here, in the compression testing tutorial:
https://www.picoauto.com/images/uploads ... rulers.jpg
I pulled out the 2 rulers from the side, but when I go to ruler settings, it's emtpy. Now I am working with the 2 rulers and the 2 additional ones from the left side, and changing their values to where I need them to be, but I would love to be able to use it as it is used above. Is it some weird setting or maybe something I need to install for that popup to work? It doesn't work on my PC or on my laptop. Using Picoscope 4423 if it is of any importance.
Thank you!
Re: Ruler settings not showing
Post by Autonerdz »
What version of Windows?
If you are running 7 with a Windows Classic theme, try changing that to Windows 7 theme.
rudolf
Post by rudolf »
Wow. Right on spot. Thank you!
Which setting does Picoscope require for this feature, because the PC is a little old and I prefer using classic theme so that visual effects don't eat up resources? I do have the "Adjust for best performance" ticked in system settings, but I prefer the simple classic look.
Post by Autonerdz »
You are welcome. Glad that got it resolved.
I don't know why the theme selection affects PicoScope behavior.
rudolf
Post by rudolf »
I see.Well I guess I gotta get used to it then. Thanks again! Have a nice day!
