CAN signal decoding
Belet
CAN signal decoding
Post by Belet »
Hi, guys
When it comes to diagnostics on CAN bus, how to confirm which unit the fauty waveform is?
We capture the CAN H and CAN L signals and decode them by Pico 6 Auto software, and we get a list of data such as ID,DLC,DATA Bytes,CRC Sequence and so on.
How can we know the message is from ECM or TCM through the sort of data above?
Many Auto Teches asked me lots of similar questions as they had encountered many troubles dealing with the CAN faults.
PicoPhil
Re: CAN signal decoding
Post by PicoPhil »
Good morning
Thank you for the post about CAN bus decoding. This now becomes a interesting subject and most of the data codes you have listed will only be known by the vehicle manufacturers. This is the DNA of the vehicle and all manufacturers will guard this with their life. All we can do is look at the data files and observe.
Thank you for the post.
Philip
Belet
Post by Belet »
picophil wrote:Good morning
Philip
Hmmm.....You are right, Phil. But can we get better ways to facilitate it ?
It's a rather hard time for many auto teches when facing problems of CAN.
J1939 is probably one of the easiest to decode with the right tools. Won't ramble on too much about it but there is some interesting info out there, and I'm no expert.
HTH
PicoPhil
Post by PicoPhil »
Hi Fat Freddy
Agree with your comment and there are thing out if you look.
Philip
Belet
Post by Belet »
Hi both,
I got it.
LM358
Post by LM358 »
You can recognize OBD2-frames because their identifiers all begin with 7.
Take a look at the following:
https://en.wikipedia.org/wiki/OBD-II_PIDs
A good way to get started is to connect a universal OBD-scanner to the car and read the "live data" with the tool. At the same time, you decode the CAN-frames with your Pico.
Try to catch some OBD-frames (with 7XX-identifier). You can even understand the data (all the info is in the Wikipedia-document).
There is a lot of traffic on a CAN-bus, so it can be difficult to catch the 7XX-frames among many others.
The best way to solve that problem is to built an acceptance filter using a µC.
If you have assembly-programmer skills, I can help you with some software for PIC18F258. I don't speak C+ nor C#.
Good luck - Eric (Belgium).
Belet
Post by Belet »
LM358 wrote:You can recognize OBD2-frames because their identifiers all begin with 7.
Thanks for your post, Eric.
It really helps a lot.
I will take account of it and try it. :D
Many thanks to all for the posts.
This is a topic we must pursue as the value of decoding data frames/packets into meaningful data will bring a new angle to diagnosis.
Just being able to identify the presence of a particular control unit would be beneficial when serial data is inconclusive.
One of the tools we can utilise when searching through decoding table is the "Filter"
Within the decoding table, click on the "Filter" option and type in the ID required to list all fames with the required ID.
In the image below, using the "Filter" option and entering ID 5CO will list all relevant data that will help the search for OBDII identifiers. (This will still remain time consuming but will help)
Take care.......Steve
Belet
Post by Belet »
Thanks for the post, Steve
Filter is a helpful function though faults on Can-bus are real puzzles to auto teches.
Best regards
Belet
