non pico pressure transducers
LucaB
Re: non pico pressure transducers
Post by LucaB »
leemack wrote:I don't know much about in cylinder pressure checks but doesn't the wps500 also measure negative pressure during a running compression test.
Hi, You are right by the rush I had not thought.
Try this probe
I repeat only work if the data entered on the relationship tension / pressure are correct and if the sensor is linear.
Robski wrote:How would that go on with in cylinder pressure ?
I do not understand question, my English is bad.
Apply otherwise
Best regards
Transducer Snapon by -30 to 500PSI.psprobe
(2.25 KiB) Downloaded 473 times
LucaB
Post by LucaB »
Hi, I forgot, if the sensor signal is not linear but logarithmic put voltage values for the different presses that then try to do probe.
Best regards
LucaB wrote:Hi, I forgot, if the sensor signal is not linear but logarithmic put voltage values for the different presses that then try to do probe.
Best regards
my 1/2 Italian is bad.Apply otherwise ??
Rush ????
The probe you created never went negative !
leemack
Post by leemack »
I configured a probe from the results of a pressure/voltage test but sith the engine running the zero voltage drops negative so the zero psi isn't correct from the start.
Without the engine running the 0psi scsle of 0.5v = 0 psi is correct. I've now got the use of a wps500 instead but it would've been nice to get it working.
Post by Autonerdz »
leemack wrote:I configured a probe from the results of a pressure/voltage test but sith the engine running the zero voltage drops negative so the zero psi isn't correct from the start.
You have now proven to yourself the problem with most transducers out there. You cannot make a custom probe for a transducer that is inaccurate. They work OK in a static measurement application but are wildly inaccurate under dynamic conditions such a running compression test.
As far as I know, there are only three transducer choices that don't have this problem. The Pico WPS, the Fluke PV350, and the DCTI. We did extensive testing here on dozens of transducer candidates for the developer of the DCTI and found them all problematic. He ended up having one custom engineered. Of these choices, the WPS is the most versatile.
Tom Roberts
The ONLY PicoScope automotive specialists in North America
leemack
Post by leemack »
Tom Roberts,
thanks for that as I thought I was going mad, so it appears it wasn't really made for the specific task I was attempting to carryout. Even with the snapon scope it proved inaccurate.
Post by Autonerdz »
leemack wrote: thought I was going mad,
I am familiar with that feeling. :roll:
You are welcome.
Tom
madhuridixit
Post by madhuridixit »
Am using PICO WPS500X Automotive Pressure Transducer (PP652) but the drop of voltage is very huge. How to rectify my issue???
