Micra K11 Fuel pump
wayner6708
Micra K11 Fuel pump
Post by wayner6708 »
Hi Everyone,
Just joined this forum and have had my 2 channel pico for a few weeks now.
My Nissan Micra K11 has a lean condition at idle with fault code po170.
The MAF , o2 sensor both check out ok and there are no vacuum leaks. I think it could be the fuel pump.
Can anyone tell me if this is a good waveform or not ?
Cheers.
fuel pump 13.07.14.psdata
fuel pump at idle
(5.99 MiB) Downloaded 868 times
tode
Re: Micra K11 Fuel pump
Post by tode »
Electrically, the fuel pump does not have anything, but we need to see mechanically, or a problem with the pressure regulator, to be sure, you can check the fuel pressure and flow. :D
Chris C Stahl
Post by Chris C Stahl »
Fuel pump is turning 7816 rpm is this a little high or is this normal? I thought it should be a little lower.
