If you cannot remember your password for the forum (I know many people take advantage of the "Remember Me" function), and therefore are unable to log into the Waveform Database, please feel free to drop me a PM saying so.
I can reset your forum password for you. Please also include a preferred email address for me to send the new password to.
Regards,
Forum password & Waveform Database access
Mike Valentine
Re: Forum password & Waveform Database access
HI mike im unable to access the waveform data base its saying i dont have a account also im unable to private msg you as its saying not authorised sliamliam@hotmail.co.uk
Hello i cant log into waveform database and i cant private msg you it wont met let me.
Hi There,
I will look into this for you this morning. It is the same credentials as this forum, so it's a little strange. Will get back to you.
Please ensure you are using the most recent build of PicoScope.
https://www.picoauto.com/downloads
Mike Valentine
I can't see why you wouldn't be allowed in. Please confirm the version of software you are using (Help>About) and if possible send me a message here, or email your password.
If you would rather not do this no problem. If you would prefer I can simply reset your password, I can use that to try to login, then email you directly (if you can send me your email address) and let you know your new password.
Mike Valentine
I have the Pico 3223 connected, the software running, and I cannot access the waveform library.
May I have some assistance please?
thank you.
thank you.
Hi There,davidbry wrote:I have the Pico 3223 connected, the software running, and I cannot access the waveform library.
thank you.
The PicoScope 3223 is supported by our Automotive software, so this should work fine.
- Can you confirm you are running our latest build? - https://www.picoauto.com/downloads/
Have you logged into the Waveform library (under the File menu).
Is the PC running PicoScope connected to the internet?
Kind regards,
Mike
Mike Valentine
Hallo,
can someone explain to me how to add some of my waveforms in Waveform Database?
Check this out: topic10063.htmlRS-4 wrote:Hallo,
Interface has changed a bit but in principal it works the same.
Thanks, I just upload a few waveforms now.
