VW Polo 1,4cc No Start When Hot
antreas26
Post by antreas26 »
Good Coolant Temp.Sensor.psdata
(565.51 KiB) Downloaded 730 times
Bad Coolant Temp.Sensor.psdata
(572.95 KiB) Downloaded 713 times
Hi Guys.This is a VW Polo 1,4cc,2002 model with a BBY 16v engine.Customers complaint,the car cranks good but won't start
when hot (normal temperature).He left the car for further investigation.There was no check engine light on.With the scanner (VCDS) hooked up,there were no faults.The customer also told me that when the car is cold (on the first start) it always starts without problem.I hade a hunch that the coolant temperature sensor would be faulty,causing this problem,so i had the Pico on channel A hooked on the sensor and on the scanner i went to measuring blocks No1 monitoring what the ecu reads from the sensor.Started the car and for 20 minutes it was fine.Stopped it for 5 minutes and tried to restart but the problem was there.No start,the pico was showing 4,88 volts and the scanner -25 Celsius.So the ecu thought that the car was at North Pole flooding the system with petrol.The car started very hard after about 1 minute and when the sensor dropped to 1 volt (normal).You can see it very clearly in the psdata file.Changed the sensor with a new one and monitored again the same way as before to confirm the fix.I also upload a photo of the sensor that made the fuss.
Re: VW Polo 1,4cc No Start When Hot
Many thanks for the information and sharing the scope traces which provides undeniable evidence to the customer. This also highlights the additional use of the scope for monitoring signals over long time periods, as we tend to forget how useful this feature is. Whilst we know the scope can take millions of samples at lightning speeds, we don't always need this amount of data or processing power and this is a perfect real life example.
Liteace
Post by Liteace »
That particular type of sensor caused a non start problem on 99% of VAG's it was fitted to, I think its a little bit of overkill timewise scoping it when you can see the problem in the live data.
Quick test unplug it, if it starts then you've saved 10 mins and can move on to the next one
antreas26
Post by antreas26 »
Well Liteace i dont think that scoping the sensor for 15 minutes is a overkill timewise.You will get paid for your time.For me
being accurate diagnosing the problem by scoping with Pico in the front door and using the scanner at the back door at the same time,mostly saves time and money.
Live data (PCM/IC) > Infrared thermometer > disconnect & live data again (neg reading,confirms wiring) = <15 mins surely ?
Dave Hill
Post by Dave Hill »
Liteace wrote:That particular type of sensor caused a non start problem on 99% of VAG's it was fitted to, I think its a little bit of overkill timewise scoping it when you can see the problem in the live data.
I could not disagree more with that comment!
It only takes a moment to hook the scope up & leave it running, gathering data. Whilst it is doing so, you can busy yourself on another job.
Although I agree that these sensors are a very common fail item, I would not want to sit looking at live data, waiting for it to "glitch". I would likely just swap it out anyway, but there are occasions where I might need to demonstrate the test procedure & factual evidence of the failure.
It is a shame to see folks being knocked for posting about their workshop experiences & it does little to encourage others to offer their findings to the group.
I would also add that I don't recall a single instance of a coolant sensor fail, causing a non start on a VAG motor.
No knocking of scope use from my comment Dave, mine was just aimed at the time aspect.
Liteace
Post by Liteace »
Im not knocking scope use either, all I said was:
"I think its a little bit of overkill timewise"
Pico is a must for diag work, I also 100% agree with you, there are occasions where we might need to demonstrate the test procedure & factual evidence of the failure but most of the time the customer don't give flying, not interested & all they do is moan about the price of the repair.
You say:
"I would also add that I don't recall a single instance of a coolant sensor fail, causing a non start on a VAG motor"
is a VW Polo not part of the VAG group ?
I think every Seat Ibiza & Cordoba + VW polo & Golf they made from about 93 up to 03 was fitted with that type of temp sensor and 99% of them failed causing a non start when hot problem, we've changed 100's of them
Dave Hill
Post by Dave Hill »
You say:
Fair enough.
It just looked like the guy was being put down for his efforts.
Funny how things come across in the written word hey! :wink:
Have a good week.
