lambda sensor timing erratic; failed HC emissions at idle
hillp
Post by hillp »
Flunked emissions inspection 3 times in a month now with a '94 Chevy Suburban 5.7 L with throttle body injection and 1 heated zirconia lambda sensor in front of the cat; OBD-I. The first time it was high on HC at idle (320 vs 220 limit) and high on both HC (720 vs 220 limit) and CO (1.69% vs 1.20% limit) at high idle (2000 rpm or so). Replacing an open spark plug wire and the worn but clean spark plugs, as well as a squirrely ignition module (tach would leap about erratically while engine misfired at cruise) seemed to cure the high idle emissions at the 2nd emissions test (CO dropped to 0.02%). But nothing changed at idle; still flunked with similar numbers (306/220 HC). (There had been no OBD-I codes set the entire time, even with the horribly misfiring intermittent ignition over the past weeks.) So I figured the 100k mile old cheap aftermarket cat was fouled from all the misfiring. (I'd also read an opinion that this generation of TBI fueling systems are so inefficient at idle that one needs a cat to pass emissions even if everything else is working fine.) So I put in a new cat and lambda sensor. Driving it the first day after new cat and sensor, it set the malfunction indicator light with a lean O2 sensor code (44). The MIL extinguished itself on the next drive cycle, but I haven't yet cleared the stored code. On the 3rd emissions inspection, flunked again at idle (344/220 HC). So I hooked up my new 4423 Picoscope and monitored the brand new lambda sensor's voltage at idle. It seemed horribly erratic in its timing, with no pattern whatsoever. At cold startup it reads low, and over a minute or so creeps up to very rich, and then starts its erratic cycling when the engine goes into closed loop. The "o2 sensor erratic" data file attached shows this erratic cycling. It paints a broad band (I think) because I hadn't yet learned to use the filter. Then I set up and recorded lamda heater current (with an old current clamp I had lying around), lambda voltage, throttle position, and manifold absolute pressure. Ran it at idle, 2500 rpm, and gave it WOT throttle blips. The lambda voltage seems to behave as I'd expect at higher rpms, but sits rich for long times (11 seconds at one point) and also lean for long times at idle. (I can't seem to attach this file in addition to the first file in this posting. When I try, it deletes the first one, leaving no attachment, and clears the posted text as well. ??) I suspect that some other components (hopefully not the ECU!) are causing the ECU to erratically jerk the fuel (or air) around. My OBD-II scan tool won't plug into this OBD-I vehicle so I plan to get ahold of an OBD-I tool this week to read short and long term fuel trims. Any comments or suggestions as to what I should investigate next?
Thanks,
Pete.
20140221-0003 o2 sensor erratic at idle.psdata
(3.04 MiB) Downloaded 737 times
hillp
Re: lambda sensor timing erratic; failed HC emissions at idl
Post by hillp »
Here are screen shots of the idle, 2500 rpm, and WOT blips. Maybe the psdata file was too big to attach (~ 11MB)? The system won't let me attach it.
4_idle again.pdf
(289.25 KiB) Downloaded 565 times
3_idle and WOT blip.pdf
(281.54 KiB) Downloaded 563 times
2_ramp up to 2500, drop to idle, and WOT blip.pdf
(311.34 KiB) Downloaded 562 times
1_at idle.pdf
(308.94 KiB) Downloaded 559 times
PicoPhil
Post by PicoPhil »
Check that all parts supplied are correct for this vehicle make and model. This would not be the first time a parts supplier have supplied wrong parts ie o2 sensor which will not work with this model. Are you using aftermarket parts or OEM parts for this vehicle, this could all effect your end results. Have you tried re adapting the basic setting and taking the vehicle for a full drive cycle.
hillp
Post by hillp »
All aftermarket parts except for plugs. What do you mean adapting the settings and taking for a full drive cycle? You mean capturing GB of data? I could do this but I'm not sure what I'd be looking for beyond what I've done already.
Thanks.
