2005 Corsa C Misfire
andygarv
Re: 2005 Corsa C Misfire
Post by andygarv »
Thanks FF, got a capture of primary current and secondary voltage, hope this is of use and interest to you. As Robski said, this ignition system does multi strike as a feature, not a symptom or fault. Not sure under what conditions but have seen it regularly which checking this vehicle, new one to me. Cheers, Andy
05 Corsa Ign Pri current + Snd Volt.psdata
(1.31 MiB) Downloaded 472 times
Much appreciated. The multi strike is not my area of interest. The devil is often in the detail. :twisted:
Edit: It has defiantly changed to an expected waveform. Interesting.
