I.A.C Valve????
ecosse
Re: I.A.C Valve????
Post by ecosse »
whos mitchel ?
thanks for input rob gona try and get on it asap, and just verify and load my wiring checks to pcm if all good i may take the iac to bits :shock:
customer is trying to find the old one he took off
cheers
kp
Re: I.A.C Valve????
Mitchell on demand, our info systems don't seem to be a patch on what they use over the pond.
PS I don't think Tom will be too charmed hosting Derrecks capture here.
ecosse
Re: I.A.C Valve????
Post by ecosse »
didn't realise i was doing wrong by posting derecks capture here oops :roll:
found this diag though on a google search :D
Re: I.A.C Valve????
Just had an IAC on a wrangler (TJ) (short on to fuel rail inside conduit, rail had pushed through split).
4 wire. Each pair was always switching so two high and two low. As a thought looking at yours I would thinking Brown/Green channels OK. Blue/Red open circuit somewhere after the IAC.
But as Robski pointed out Amp clamp will tell you.
What is the definition of that P1505?
HTH
Re: I.A.C Valve????
Kenny
from the diagram you were given it looks like just a motor so find your pairs & as above !
ecosse
Re: I.A.C Valve????
Post by ecosse »
thanks guys will post back ASAP :D
ScannerDanner
Re: I.A.C Valve????
Post by ScannerDanner »
Here is a known good capture of a Chrysler 4-wire stepper type IAC valve. I have included the jpg picture from my eBook and the original psd files.
I believe you have an open in one of the drivers in the PCM (could be an open in one of the wires too). If my suspicions are correct, when you unplug this IAC you will only see activity on 3 channels. The fourth will be dead.
This may also explain the weird pattern on the beginning part of the one channel. (failing driver)
Also as Robski suggested, a current measurement would tell you the same thing. I believe you will have flow on only two wires.
4.psd
IAC unplugged during bi-directional extend and retract mode
(462.6 KiB) Downloaded 490 times
3.psd
IAC plugged in during bi-directional extend and retract mode
(481.51 KiB) Downloaded 471 times
ScannerDanner
Re: I.A.C Valve????
After looking at your file closer. I believe you will find the issue on the red and blue channels (one of those two has a completely open driver or an open control wire). Also the tan channel looks like crap, but it is actually still functional.
ScannerDanner
Re: I.A.C Valve????
Fat Freddy wrote:Just had an IAC on a wrangler (TJ) (short on to fuel rail inside conduit, rail had pushed through split).
HTH
Oh crap, sorry I didn't read your post before posting my response. I agree with you completely.
Re: I.A.C Valve????
:lol: :lol: :lol:
Voltage spikes indicate current flow
Would this only apply where an inductive circuit is operating correctly?
In other words the lack of a spike could indicate poor current flow or a shorted winding? Is that correct?
