motorbike ignition fault
Re: motorbike ignition fault
Fat Freddy wrote:To me, it kind of looks like it's tracking to ground.
What colour are your plugs?
1&4 does but what about 2&3 ?
I think the same.
First kick on the Primary and nothing on the secondary.
tiggerbiker
Post by tiggerbiker »
here are the latest traces i have obtained - hope they are useful,
robski, your picture was very helpful - thanks
tiggerbiker
oops - heres the traces
bandit12 coil 2+3.psdata
(192.35 KiB) Downloaded 450 times
bandit12 coil 1+4.psdata
(202.87 KiB) Downloaded 423 times
ign. pickup + pri. amps.psdata
(1.88 MiB) Downloaded 438 times
Fat Freddy wrote:I think the same.
Is it not correct that everything after the EMF kick (spark line) in the primary is a feedback of the secondary ? so why don't they match then if the secondary is shorting to ground(picture in previous post) (picture below of 1&4 which i agree looks like short to ground) ?
OP can you verify if you were coupled to the correct side of the coil secondary (+/-) as you don't seem to have changed probes & there is a strange sub zero voltage going on ?
tiggerbiker
hi, yes i have connected to the correct feed.
