Injector flow monitored with a psi transducer on the rail
ScannerDanner
Post by ScannerDanner »
Hello guys
I had a few requests for this,so here are my captures that I used in my latest video. I took these at idle and at higher RPMs.
a. Idle.psdata
Idle speed
(1.49 MiB) Downloaded 881 times
b. 2000 RPM.psdata
2000 RPM
(1.49 MiB) Downloaded 836 times
c. 2500 RPM.psdata
2500 RPM (not sure what happened to rail pressure here. I looks like the pump in interfering with the ability to see the injectors here?
(1.54 MiB) Downloaded 823 times
d. 3000 RPM.psdata
3000 RPM, it is cleaner here, but I believe the psi drops from the injectors are more delayed in timing to the electrical function of the injector at this speed.
(1.52 MiB) Downloaded 804 times
GRUSS
Re: Injector flow monitored with a psi transducer on the rai
Post by GRUSS »
Excellent video Paul, the pico is good here but I do like the manual injector pulse test as well. Probably a little clearer to understand until you've dealt with a handful. :)
