VW TDI Camshaft Sensor (PD encoder and CR)
TDI Guy
Post by TDI Guy »
On pre 2008 VW TDI engines, there was a camshaft position sensor that monitored a disk with patterns, so that sensor was really an encoder - could tell camphase and engine position.
On the modern common rail TDI I don't know what the story is, does it monitor one splot, four slots where one slot is a different size or a double slot, or a pattern enoder.
So what I am wondering is, for both engines, how do you go about hooking up the scope, is there a varying voltage for different encoder positions or a digital word, or what is the story?
Sample cam traces would be great if anyone has these.
Thanks in advance.
TDI Guy
olympia
Re: VW TDI Camshaft Sensor (PD encoder and CR)
Post by olympia »
This is what i have from a 2005 golf 2.0 TDI BKD engine code.
Hopes that helps
Golf BKD 2.0 good camshaft signal.psdata
(409.42 KiB) Downloaded 937 times
