After saving a pattern using a trigger of "repeat" and then opening that pattern, you only get partial image. Meaning the trigger gets moved to the center of the screen and any traces to the right of trigger are no longer visable. I have tried using other tigger channels - same result.
In order to help you more effectively I will require the following information:
1) What product are you using (the hardware)
2) What version of the software are you using?
3) What operating system are you using?
4) Could you send the wave form you saved so I can try and recreate your settings.
I am aware of this issue with the 6.0.8.2 version. It will be corrected in a later release. Send the saved file to Ziko anyway along with additional information so they can get a better handle on this issue. I think this has been solved for the next build though.
Thanks for the response Tom and Zeko. I figured they already knew. Zeko the software is 6.0.8.2 and scope is 3423 and it is on a XP service pack 2 machine. The attached file is a .jpg because you cannot upload .psddata files.
Hi, After downloading and reinstalling I see the same version 6.08.2. I followed the link from the newletter. This is the same version as previously released, right??
ALso the saved pattern will display correctly if you use the "Pretrigger" Box to adjust the trigger and not drag and drop the yellow trigger marker.
