crank, non start, no fuel pressure
Kudugar
Post by Kudugar »
HI All, please review scope on crank & cam correlation for non start but crank condition. freelander 2 2.2auto 2010 model. driving normal parked and non start thereafter. diesel pump overhauled and injectors new bocsh. no fault codes relative compression 3 x 100% and 1x 99%. fuel is getting through diesel pump but very low pressure, voltage on SCV is battery voltage and getting PWM on second control line of SCV.
Land Rover_Freelander 2_2010_Diesel_20210410-0001.psdata
(10.03 MiB) Downloaded 283 times
vasek
Re: crank, non start, no fuel pressure
Post by vasek »
Hi.
The chain is out.
Here You go :
Kudugar
Post by Kudugar »
THANKS YOU VERY MUCH,VASEK :D
will it be possible to forward me the actual psd file so i can measure as well at what degree i am out if possible?
i will update case once problem is located, it has cambelt and separate chain between cams.
Kudugar
Post by Kudugar »
Update, on changing cambelt using factory locking tools the variance in correlation seems to me to have gone worse.
blue is voltage relative comp test, green crank hall effect and red camshaft hall effect, voltage seems high on cam sensor as well? i am getting fuel pressure but only after 20 seconds of cranking
Land Rover_Freelander 2_2010_Diesel_crank non start 20210415-0003.psdata
(4.79 MiB) Downloaded 265 times
Kudugar
Post by Kudugar »
hi , attached is new more complete test including cam, crank, injector no 1 and in no 1 cylinder pressure test with wpx500, still no dtc's logged, fuel pressure only start increasing after 20 seconds of cranking , i suppose as result of incorrect cam crank correlation?
your thoughts is highly appreciated.
Land Rover_Freelander 2_2010_Diesel_non start 20210429-0001.psdata
(5.32 MiB) Downloaded 277 times
Kudugar
Post by Kudugar »
rescoped after refit of cambelt with pins, seems to have vacuum now and early valve event? your thoughts pls
cambelt redone Land Rover_Frredone cambelteelander 2_2010_Diesel_20210504-0001.psdata
(4.6 MiB) Downloaded 261 times
kona
Post by kona »
Kudugar
Post by Kudugar »
UPDATE, i redone in cyl comp test on all 4 and cyl 3 has no compression, and cyl 1 & 2 has the vacuum event noted, only cyl 4 seems to have good spec and hardly any vacuum event.
cyl 4 Land Rover_Freelander 2_2010_Diesel_20210507-0005.psdata
(2.27 MiB) Downloaded 251 times
cyl 3 no compLand Rover_Freelander 2_2010_Diesel_20210507-0007.psdata
(406.58 KiB) Downloaded 255 times
cyl 2 Land Rover_Freelander 2_2010_Diesel_20210507-0008.psdata
(477.92 KiB) Downloaded 258 times
cyl 1 Land Rover_Freelander 2_2010_Diesel_20210507-0009.psdata
(439.64 KiB) Downloaded 266 times
