Checking coil drivers on a 2000 ka wasted spark system
Columbus
Post by Columbus » Mon Sep 16, 2013 12:44 pm
Been playing with a KA this morning which won't start no spark on 1 and 4 checked the wiring back to ecu and its good so i need to check the coil drivers. Live to coil is good.
Having very little experience with my pico i don't want to damage a the car or b the scope so need a little help with connection.
If scoping at the ecu terminals for the negative switching on the coil do i need an attenuator?
Should i expect a primary wave form?
thanks
Re: Checking coil drivers on a 2000 ka wasted spark system
Post by Robski » Mon Sep 16, 2013 4:26 pm
Yes, why ECU terminals, surely you would want the coil end ?
Yes.
Columbus
Post by Columbus » Mon Sep 16, 2013 5:52 pm
ecu end as its easier to get too
and its the ecu that does the switching which is what i want to see.
Pretty sure the ecu is fudged anyway as i have no spark on 1+4 and spark drops out on 2+3.
Post by Robski » Mon Sep 16, 2013 6:14 pm
Columbus wrote:ecu end as its easier to get too
I am well aware the PCM controls the coil, if you have volt drop between there & the coil you won't see it scoping at the PCM will you & then you would scope both ends !
Scoping at which end depends on inputs/outputs, you're obviously not aware of that ??
PS you're welcome ;)
Post by KimAndersen » Mon Sep 16, 2013 8:28 pm
Did you check the wire from the ignition coil and back to the PCM with a DMM and if it's the case, what readings do you get ?
I would suggest, that you make a resistance test from the fuse through the ignition coil and back to the PCM, just to rule out any parasitic drains to ground or any open circuit.
Kim
