2004 PT Cruiser 2.4L HO Turbo
cudadriver
Post by cudadriver » Sat Jun 22, 2013 4:00 pm
At idle with the air conditioning on (its working great VERY cold air) and the car in gear, the engine sounds and feels like its missing. once you start to go engine and air work great. If I turn the air off under the first set of conditions the engine sounds and runs great. Can't figure this one out.
Re: 2004 PT Cruiser 2.4L HO Turbo
Post by Robski » Sun Jun 23, 2013 8:13 am
What testing & results have you done/got so far ?
Post the captures you have got so far ........
Also what sticks out in a wiring diagram ?
cudadriver
Post by cudadriver » Sun Jun 23, 2013 12:28 pm
Only done the car's self diagnostic, got a P301. Not sure what you mean by "sticks out in the wiring diagram".
Avdr
Post by Avdr » Sun Jun 23, 2013 12:46 pm
Is it an expansion valve or an orrifice tube AC system?
cudadriver
Post by cudadriver » Sun Jun 23, 2013 6:55 pm
Don't know the difference on the AC. But as an update, it appears the AC has nothing to do with it other than causing an extra engine "load" at low rpm. Had a chance today to try heavy acceleration with the AC off and got a flashing check engine light. Light went out as soon as I backed off the throttle, check the self diagnostic and the only code I got was P301 which I know is a detected misfire in cylinder 1. Does it just need a tune up with wires or is there something else that can cause that issue? Thanks
