Acc. Pedal Position
Dundeeguy
Acc. Pedal Position
Post by Dundeeguy »
Hi guys,
Had an Astra diesel go into limp mode. Code read and had a couple of codes for accelerator position sensor tracks 1 and 2.
So, thought this can be tested with the scope and off I went. On zooming in on the attached waveform I could see the signal drop off slightly every so often on track 2 (blue trace) Bingo, proud as punch got the boss to order a new part. Only problem being, the new part does the same!! :oops: :evil:
Car goes fine and no codes getting logged, just looking for thoughts on the waveform.
Thanks,
Kevin
Astra APP.psdata
(617.75 KiB) Downloaded 639 times
modo
Re: Acc. Pedal Position
Post by modo »
See if it happens on the power and ground circuits of the unit to isolate the drop out. It happens at a constant rate of approx 170mv looks like something is switching on and off may have to go to the throttle body and see if you get the same result there.
Valhalla
Post by Valhalla »
Looks like something switching at a period of 320ms constantly, probably on the track 2 voltage positive line. Seems to be a proportional drop-out depending on the sensor output signal, as you can just see the same drop-out throughout the APP = 0% part of the trace. Would that conclusively make it a positive line problem? Certainly, whatever it is that is causing the APP2 sensor signal to fail, it has got a very constant period of 320ms. Might be worth checking a wiring diagram to see what else is on that sensor supply line....
If I were your boss, I wouldn't blame you. Thought for the day.
Darren Cotton
Post by Darren Cotton »
How did you get on with this?
is it an astra H?
Darren
Post by Robski »
Darren Cotton wrote:How did you get on with this?
is it an astra H?
Darren
Are you thinking what i'm thinking :?:
Dundeeguy
Post by Dundeeguy »
Ok, car came back today!!
Checked earths and 5volt feeds at multiplug. All spot on. Track 2 drops voltage same as before. Have tested both 5volts and earths when it happens, and both remain stable :? Everything has been checked at pedal.
Went and carried out tests as per vauxhall tech info, and it tells me to replace the pedal :x I can't see us being unlucky getting a faulty part that does the same.
Darren, it is an Astra H on a 54 plate fitted with the 17DTL engine.
Awaiting the customer calling to confirm exactly when and how fault happens.
Cheers
Darren Cotton
Have you actually looked at a wiring diagram for the pedal?
Darren
Dundeeguy
Post by Dundeeguy »
Just trying to browse the diagram while having a bite to eat and speak to customers!
I see it seems to pop through the instrument cluster, then through underbonnet fuse box then onto the ECU.
Would these other components cause the track 2 voltage to drop out? The 5volts remains constant for the tracks, and I'm measuring at the pedal. I could understand it happening if I were testing at the ECU??
I'm obviously missing something here. Now starting to think the drop out isn't causing the fault and is normal!
Cheers
Post by KimAndersen »
Hi.
I was wondering if the new APP sensor should be adapted to the PCM ?
I know that some cars with APP sensors use adaptation and others don´t.
With the serial tester connected what values are you getting from the APP sensor in terms of percentages ?
Kim
Valhalla
Post by Valhalla »
Dundeeguy wrote: I see it seems to pop through the instrument cluster, then through underbonnet fuse box then onto the ECU.
I think that you are going to have to temporarily pull the pin for APP2 signal input to the EDC15C7 controller, and then see if the signal you are measuring at the pedal for track 2 is still being pulled down. No question that whatever is causing the problem is very consistent; period is exactly 320ms, pull down is by 6.6% (+/- 0.2%) of the signal voltage. If you had a spec for the pedal track resistance, you could probably work-out the load impedance that is being applied.
I have been wracking my brains for the things that operate on a 320ms cycle. Assuming that this isn't the ECU (i.e. problem does not go away by pulling the APP2 signal pin at the ECU), then it is likely that the instrument pack is a gateway to something else that wants the throttle pedal signal (transmission? abs? ) but hasn't been set-up with the signal directly from the ECU over a CANbus.
I really hope you fix this one, so I can get some sleep. :roll:
