Advice on waveform
Re: Advice on waveform
Post by Fat Freddy » Wed May 29, 2013 11:05 am
I think the ignition needs a closer look.
Your scope set up needs some attention though (avoid useing the drop down set ups if you can). A sample rate of 1us for igntion (check in properties), 20Kv for a kick off and enough time (seconds) on the screen to get a decent capture but not so big the file size is excessive for posting.
Could you access primary?
onboardtech333
Post by onboardtech333 » Wed May 29, 2013 1:08 pm
This has a coil per plug with one plug wire to each iridium plug. I also attached the secondary pattern for the companion cylinder here
CamaroCyl3.psdata
(1.67 MiB) Downloaded 303 times
onboardtech333
Post by onboardtech333 » Thu Jun 20, 2013 10:37 pm
Just to close this out . The exhaust valve seats had a small ridge of carbon. Valves were lapped and seated . All is well in New York once again. Thank you all for the input!
Post by Robski » Thu Jun 20, 2013 10:52 pm
an after repair running comp capture ??
double post :roll:
onboardtech333
Post by onboardtech333 » Fri Jun 21, 2013 3:25 am
Sorry don't have one yet. The customer was in a rush to take it out for the weekend. I should be able to steal it back from him for a finished product snappy. :lol:
