V6.7.21.2 hangs on loading
StuW-753
Post by StuW-753 » Sat May 18, 2013 12:28 pm
Help, please!
I have just installed the latest version of the software and it is hanging up with the splash screen displayed, at the 'Enumerating Devices' stage.
I previously had V6.6.x installed and working, and have un-installed and re-installed both versions with consistent results: 6.6 works, 6.7 hangs. I have even re-downloaded 6.7 to eliminate download errors...
The release notes don't indicate anything which may be causing this problem on my admittedly ageing laptop. :wink:
I would be grateful if anyone can shed some light on this for me.
Re: V6.7.21.2 hangs on loading
Post by Martyn » Mon May 20, 2013 9:09 am
Can you send a copy of trace.xml to support@picotech.com
You can find this file in the directory at C:\Users\{yourloginname}\AppData\Local\Pico Technology\
StuW-753
Post by StuW-753 » Mon May 20, 2013 1:37 pm
Thanks Martyn,
I've emailed the trace file to support@.
I took a look at it myself and saw that it is reporting missing .dll files. I searched for them and found that they are not present on my machine.
Incidentally, I omitted to mention that I am running XP SP3. The release notes did not indicate that it is not supported on this platform so I assumed it was...
Thanks for your help
Post by Martyn » Mon May 20, 2013 2:19 pm
The missing dll's are not an issue, that message is just an information report by the software. The file has been passed on to our development team for investigation.
