WPS waveforms
Damian Mc Bride
WPS waveforms
Post by Damian Mc Bride » Sun Jan 20, 2013 8:37 pm
Hi guys was just playing with WPS on a K12 micra today i took a capture of exhaust pressure and current on cyl 4 coil.
I disconnected an injector in the middle of the capture can you pick whitch cylinder it is and tell me how you came to a choice.
03 Micra K12 WPS in Exhaust running bad.psdata
(1.79 MiB) Downloaded 412 times
Next is a cranking compression waveform, any tips on setup or dose the setup look ok. I have a lot of learning to do now :D
Thanks Damian
Liteace
Re: WPS waveforms
Post by Liteace » Sun Jan 20, 2013 9:30 pm
I would say cylinder 3 but there again Im still learing as well + I dont have a WPS and it would take me a lot as what your doing to get the hang of it
Re: WPS waveforms
Post by Robski » Mon Jan 21, 2013 12:01 am
Works out @ cyl #1 to me going by +1 rule.......
I'm not sure what you're asking with the cranking compression capture ?
Did you have the throttle wide open as you would with a gauge ?
Re: WPS waveforms
Post by Fat Freddy » Mon Jan 21, 2013 12:26 am
Robski wrote:Works out @ cyl #1 to me going by +1 rule.......
Rats! You beat me to it.
To busy making pretty pictures.
Re: WPS waveforms
Post by Robski » Mon Jan 21, 2013 12:32 am
I was going to map it out too but did it without, I was waiting for Damian to reply then I planned to email him with explanations :D
Lol at the pretty pictures comment :lol:
Damian Mc Bride
Re: WPS waveforms
Post by Damian Mc Bride » Mon Jan 21, 2013 7:56 am
Hi yes it was cyl 1 injector disconnected. :)
So to work it out do you +1 to the cyl that lines up on screen to allow for length of exhaust.
Rob the cranking compression test i was just checking is that how you would set up for taking capture for your libarary or would you leave out the cam/crank.
On this K12 you have to remove plastic housing with throttle body to get at spark plugs so no air restriction on cranking compression.
Thanks Damian
Damian Mc Bride
Re: WPS waveforms
Post by Damian Mc Bride » Mon Jan 21, 2013 8:11 am
Just thought after looking at FFs post again its not length of exhaust its No 1 on exhaust stroke :oops:
Thanks Damian
Re: WPS waveforms
Post by Robski » Mon Jan 21, 2013 8:14 am
Damian
when I get to my PC i'll do you an explanation with pictures.
Liteace
Re: WPS waveforms
Post by Liteace » Mon Jan 21, 2013 8:15 am
:oops: I could edit mine and change my 3 to a 1 but I wont :D, this is the 1st page ive gone straight to this morn I was dying to know, with the picture and a a little explanation I can sort of see it now. Do one for me as well please Rob :?
Damian Mc Bride
Re: WPS waveforms
Post by Damian Mc Bride » Mon Jan 21, 2013 8:27 am
Thanks Rob
Damian
