AC ripple test
Liteace
AC ripple test
Post by Liteace » Wed Nov 21, 2012 8:34 pm
Bit of a Div question this one, when I get the answer I'll go:
"oh yer, didnt think of that :cry: "
Done an AC ripple test today, here the waveform
Ripple test.psdata
(382.49 KiB) Downloaded 462 times
I also done a bettery test, the battery failed the test, didnt save it but im sure it said at the bottom somewhere AC test OK. I put a volt meter, switch to 200v AC on the battery and got a 30.9 reading, does this waveform look ok ??
Re: AC ripple test
Post by Alan » Wed Nov 21, 2012 9:35 pm
That ripple waveform looks normal to me. The spikes are interference from ignition or injectors and are pretty normal - wires in the loom run pretty close to each other so such spikes are a fact of life. Switch on a filter - about 10kHz and they will go away.
As for the voltmeter, some of them can not cope well with spikes so give odd readings. Best to rely on the scope :D
Feel free to save the battery test and post here for comment.
