cam crank sync wave form
veejful
Post by veejful » Thu Nov 15, 2012 10:27 pm
Hello folks,
I have got a 2003 Seat Alhambra 1.9 PD tdi (engine code ASZ). with rough idle. head has been rebuilt by some other garage before(worn cam lobs,common on these engines as you know) I need the cam/crank sync to check the timing first before the dissemble. Can someone help me out with the known good cam/crank wave form please(and the PD injector wave form if its possible). Your help would be much appreciated.
Thank you!
PicoMike
Re: cam crank sync wave form
Post by PicoMike » Fri Nov 16, 2012 11:44 am
I believe PicoScope Automotive has a VAG PD Injector preset?
Automotive>Actuators>Injector (diesel)>VAG PD
As for CAM/CRANK there is a pre-set under "Advanced Tests>Cam and Crank Sensors"....not sure if the waveform example you see will be what you get as a result, but the settings should be suffice?
Mike Valentine
veejful
Post by veejful » Fri Nov 16, 2012 1:36 pm
Thanx Mick,
I got the PD injector wave form. But I still need the good cam/crank wave form for this vehical. So I can match it up to see if the timing is correct. Has anybody got a known good cam/crank wave form for this vehical? Thank you!
Darren Cotton
Post by Darren Cotton » Fri Nov 16, 2012 4:08 pm
Sorry but I Can't Help with the Cam/Crank But have a PD Injector
Darren
veejful
Post by veejful » Tue Nov 20, 2012 2:41 pm
Thank you Darren!
