What happened to "Duty Cycle Low" measurment
ScannerDanner
Post by ScannerDanner » Fri Mar 09, 2012 10:13 pm
I was showing my students how to monitor a solenoid type IAC in class. When I added some measurements I couldn't change my duty cycle to measure the low portion of the waveform. As this was a ground side switched circuit. It was important to be able to do this as the "on-time" is the low portion of the waveform. I used to be able to select Duty Cycle Low or Duty Cycle High. What am I missing?
Re: What happened to "Duty Cycle Low" measurment
Post by Alan » Tue Mar 13, 2012 9:46 am
Yes, that measurement does seem to have gone AWOL so we will start a search to find out where its gone.
A bit of a messy work around would be to create a maths channel to invert your signal then measure the duty cycle of the inverted signal. You can hide the maths channel from display. Not ideal but should work for now.
ScannerDanner
Post by ScannerDanner » Tue Mar 13, 2012 11:51 am
Thank you Alan, I will try that
Dave Hill
Post by Dave Hill » Sat Mar 17, 2012 4:04 pm
ScannerDanner wrote:I was showing my students how to monitor a solenoid type IAC in class. When I added some measurements I couldn't change my duty cycle to measure the low portion of the waveform. As this was a ground side switched circuit. It was important to be able to do this as the "on-time" is the low portion of the waveform. I used to be able to select Duty Cycle Low or Duty Cycle High. What am I missing?
Hi Paul (is it Paul?)
I watched your video the other day (on this thread.. http://www.picoauto.com/support/topic9212.html ) & I thought it demonstrated Pico very nicely. I thought the projected image & the way you controlled the scope by with a "touch screen" kind of method was very cool. I want one! :wink: If you don't mind me asking... What system is it that you were using to do the demo?
I noticed that you drew attention to the duty cycle measurement & the fact that it only measures the "duty high". To be honest I don't think I have seen the "duty low" option in any Pico 6 software build. I know the old Pico 5 software used to have this option though.
Strange how they didn't think it important to put it back.
Maybe they will now?
ScannerDanner
Post by ScannerDanner » Sat Mar 17, 2012 4:52 pm
Hey Dave
Yes my name is Paul and I was using something called a Smartboard. It is cool isn't it? I am blessed to have one for sure. It has been a wonderful addition to my class. Thanks for your comment on the video!
I talked to some of the pico guys and they are looking into the duty cycle low measurement for us.
Paul
